• Print Friendly and Internet Explorer Problem
    Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » Print Friendly and Internet Explorer Problem
    • This topic has 1 reply, 1 voice, and was last updated 6 years ago.
    Firstly, apologies to Woody et al because I still occasionally have a need to use Internet Explorer on my Windows 7 machine.
    Now, my problem.
    I often use Print Friendly with IE11, from a button (javascript) on the Favorites bar, to strip the “garbage” from a web page, prior to saving it to a PDF file.
    Never had any problems until recently, when it suddenly stopped working.
    However, if I copy the URL of the page in question to the printfriendly.com web page, all works OK.
    The problem only started approximately 2 weeks ago, so I’m wondering if anyone else has experienced something similar.
    All I can think of is that it’s caused by the latest (January 2019) MS security update, which from memory I installed around the time the problem appeared.
    I would be interested to hear if anyone else uses Print Friendly with IE11, and if so if they have seen this same behaviour.  Even better, if there is, have they found a ‘fix’ for it.
    AusJohn
    • #326307
      * Update *
      I’ve been corresponding with the developer, and he’s finally found what the problem is, and will fix it ASAP.
    Reply To: Print Friendly and Internet Explorer Problem
