My computer is set to go to sleep when it reaches critical battery level, which is set at 13% when the computer is on battery. Sometimes, however, when the laptop is on battery, suddenly shuts down. When I turn the computer back on again, I see that the battery went below 13%. When I plug it in and turn it back on, it shows the battery meter at below 13%. I think what is happening is that it goes all the way down to 0% at times and then shuts down on me when the battery is drained. This probably happens half the time and the other half, the computer goes to sleep as it should. How can I get the latter to always happen?
Power settings
Home » Forums » AskWoody support » Windows » Windows Vista, XP and earlier » Questions: Vista, XP back to 3.1 » Power settings
- This topic has 6 replies, 3 voices, and was last updated 14 years, 10 months ago.
Viewing 5 reply threadsAuthorReplies-
WSMedico
WSjmt356
AskWoody LoungerMay 24, 2010 at 7:31 pm #1225423I purchased this laptop, which came with the battery, less than two years ago in August of 2008. Another issue I have experienced is that my power icon has often displayed the message “plug in, not charging.” That makes little sense to me, as the laptop should be either plugged in or not charging; I can’t see how it can be plugged in and not charging. Also a sign for a new battery?
DaveA
AskWoody_MVP -
WSMedico
AskWoody LoungerMay 25, 2010 at 4:12 am #1225490I have to agree that this does not sound like a Windows problem, it sounds like a hardware problem. Dave’s suggestion that the charger should be checked out is sound. This might be the least costly option. If you know someone with another charger, or have a place to go check the charger then do so. A 2 year old battery could be having problems as well. I would think the battery should last longer than that, but who knows. The same method for checking the charger should be able to check the battery as well. If a known good charger will not charge the battery then…. If a know good battery will not charge on your charger…. Should not be a difficult troubleshooting problem.
WSjmt356
AskWoody LoungerMay 25, 2010 at 5:08 pm #1225557I don’t think it’s the charger. I have tried three different chargers and the battery is not showing up as charging. I will have to order a new battery to see if the issue is the battery. By the way, the battery has had this issue in the past. But usually for only a couple of minutes or hours. This is the first day I have gone three days with it showing itself as not charging.
WSMedico
Viewing 5 reply threads -
Looking for personal finance software with budgeting capabilities (Awaiting moderation)
cellsee6
3 hours, 28 minutes ago -
ATT/Yahoo Secure Mail Key
Lil88reb
7 hours, 52 minutes ago -
Devices with apps using sprotect.sys driver might stop responding
12 hours, 14 minutes ago -
Neowin – 20 times computers embarrassed themselves with public BSODs and goofups
EP
20 hours, 49 minutes ago -
Slow Down in Windows 10 performance after March 2025 updates ??
arbrich
6 hours, 14 minutes ago -
Mail from certain domains not delivered to my outlook.com address
pumphouse
5 hours, 12 minutes ago -
Is data that is in OneDrive also taking up space on my computer?
WShollis1818
15 hours, 51 minutes ago -
Nvidia just fixed an AMD Linux bug
2 days, 7 hours ago -
50 years and counting
4 hours, 26 minutes ago -
Fix Bluetooth Device Failed to Delete in Windows Settings
Drcard:))
Licensing and pricing updates for on-premises server products coming July 2025
2 days, 18 hours ago -
Edge : Deprecating window.external.getHostEnvironmentValue()
Rethinking Extension Data Consent: Clarity, Consistency, and Control
OneNote and MS Word 365
2 days, 20 hours ago -
Ultimate Mac Buyers Guide 2025: Which Mac is Right For You?
Intel Unison support ends on Windows 11 in June
April 2025 — still issues with AMD + 24H2
Kevin Jones
12 hours, 22 minutes ago -
Windows 11 Insider Preview build 26200.5518 released to DEV
3 days, 8 hours ago -
Windows 11 Insider Preview build 26120.3671 (24H2) released to BETA
Forcing(or trying to) save Local Documents to OneDrive
PateWilliam
3 days, 17 hours ago -
Hotpatch for Windows client now available (Enterprise)
3 days, 5 hours ago -
MS-DEFCON 2: Seven months and counting
My 3 monitors go black & then the Taskbar is moved to center monitor
saturn2233
4 days, 2 hours ago -
Apple backports fixes
3 days, 9 hours ago -
Win 11 24H2 will not install
Michael1950
Advice to convert MBR to GPT and install Windows 11 Pro on unsupported PC
Andy M
Photos from iPhone to Win 10 duplicating/reformatting to .mov
J9438
2 days, 15 hours ago -
Thunderbird in trouble. Here comes Thundermail
Get back ” Open With” in context menus
4 days, 17 hours ago -
Many AMD Ryzen 9800X3D on ASRock have died
3 days, 9 hours ago
