• Power Options Properties
    Hi –
    I set Turn off monitor to ‘after 25 mins’ but it turns off after 10 mins.
    I then indicated 2 mins and that worked.
    I then re-entered 25 mins but it turned off after 10 mins. How can I change this to what I want?
    Viewing 4 reply threads
    • #1239390
      Hi curious,
      Is it possible that you have the blank screen saver set to engage after ten minutes? If so, that would explain the difference. A blank screen saver would appear as though the display power off had kicked in.
    • #1239391
      Once again Gerald, you beat me to the punch. A blank screen saver would answer this question. The easiest way to prove this is to set something else for your screen saver.
    • #1239394
      Bingo!!! Thank you so much. The screen saver was/is “Windows XP” yet when the 25 mins is up the screen is blank (black). Does that, too, make sense? I’d rather, if possible, have a screen saver so I don’t think something went wrong with the PC….
    • #1239395
      I stopped setting a screen saver when I got rid of my last monochrome monitor. I think they called it a “Paper White”. There were also Amber and Green Screens. Ah, the good ol’ days!
      Screen savers were designed because those old monitors ran at a very high intensity and the screen would burn with whatever design was left on them for very long, like a menu or LOGO screen.
      In came color monitors and out went the screen savers.
      Today, with the LED or LCD monitors, screens don’t burn and screen savers are as out of date as the wash-board or the butter churn.
      If you want to set power options to be most efficient and useful, set Turn Off Monitor to NONE and set Turn Off Hard drive to 10 minutes. All other options to NONE or NO, or NEVER.
      That’s the way I set all my computers.
    • #1239396
      Again my thanks.
    Reply To: Power Options Properties
