Hi after 40+ years of playing with computers I have run into a problem I can not solve and first time have to look to an online group. I have never posted so not sure if I am in the right area but here goes.
I recently purchased a WD My Cloud EX2 Ultra with the plan to populated the unit with two Seagate 8 TB NSA IronWolf drives. I installed the first IronWolf drive and proceeded to add video files to the drive. Now I find in reading the manual from WD that they do not recommending using drives with a total capacity of 16 TB or over with the power supply in they sent. It was a 12 V 3.0 Amps 36Watts. They are suggesting a 48 watts unit. I checked with Seagate and they said the 36-watt unit should handle both drives. Well after installing the second drive and trying to do a backup of the 3TB of media files I had added to the first drive the My CLOUD ran for about 5 hours and then I received a power failed alert for the My Cloud. WD or Seagate has not been very helpful in providing the larger power adapter. I live in Canada and can not find on line or at any local shop a larger power supply. Not sure where to go next.
