• PFBackup does not work in Outlook 2010 as part of Office 2010 Pro Plus
    Home » Forums » AskWoody support » Productivity software by function » MS Outlook and email programs » PFBackup does not work in Outlook 2010 as part of Office 2010 Pro Plus
    I am unable to get pfbackup to work with Outlook 2010. Having installed it and added the required Registry key, I click on Add Ins in Outlook and select Backup, then exit Outlook and instead of the usual pop-up doing the backup, nothing happens.
    The Add In is selected as it should be, the registry entry is also as it should be, I have also tried Registering outbak.dll separately and it registers fine, but the backup is still not working.
    Does anyone have any ideas?
    Thanks in advance
    useful :confused:
    Reply To: PFBackup does not work in Outlook 2010 as part of Office 2010 Pro Plus
