• OneDrive, several problems
    Home » Forums » Newsletter and Homepage topics » OneDrive, several problems
    LANGALIST By Fred Langa OneDrive’s poor documentation and weak user interface can cause endless frustration. Some important OneDrive procedures are le
    [See the full post at: OneDrive, several problems]
    Viewing 10 reply threads
    • #2358767
      I find the simplest method of avoiding problems with OneDrive is to just uninstall it every time it shows up on my computer.
      Cloud storage hosted by Microsoft…  What could possibly go wrong!
      Having had numerous clients hire me to reclaim their data from OneDrive or its predecessor, place it on a locally controlled server, and make sure that OneDrive never gets used again, seems to indicate not everyone thinks OneDrive is a good idea.
    • #2358813
      Very good article!
      Some questions:
      1. How do symbolic links work if I wish to sync a folder between two or more PCs?  May I use symbolic links at both ends?  How does each PC know that its symbolic link is for the same synced folder?  What if the folder structures in the PCs are not identical?  Do symbolic links end up giving me what I used to have on SugarSync Free?
      2. At some point, OneDrive on my Win 10 Pro PC grabbed all my “Documents” and “Desktop” folders and moved them into the OneDrive parent folder.  If I want to move them out, what is the bext procedure?  And also to keep them syncing per preceding question.
      • This reply was modified 4 years ago by glnz.
      • #2358839
        Nothing works like SugarSync.
        I went ahead and bought it after the freebie went away.
        5 Macs, a Win7, a Win8.1 and an iPad SugarSynced – you can’t beat that!!!
        • #2578316
          Nothing works like SugarSync. I went ahead and bought it after the freebie went away. 5 Macs, a Win7, a Win8.1 and an iPad SugarSynced – you can’t beat that!!!
          Hi PK. I just got a Macbook Air 15”. I backed up my Windows machine with Macrium and set it aside, finally it only took 2 years for me to get there!! I will fire it up occasionally to run updates.  I had Carbonite for cloud b/u, but it didn’t work out transferring to the Mac, for me, though they do support MACOS.  I checked out idrive and backblaze too.  I knew about Sugar Sync due to your positive comments about it. Are you still using it?
          I signed up for the 30 day trial.  So far, so good.  I don’t have a lot of data 45gb used out of 100gb, mostly word & excel documents.  I set up Time machine backups for the Mac.
          I backed up my documents and some old pictures that were on my laptop.  Are there any other documents from the Mac I should backup?  What, if anything, are you backing up from your IOS devices? I want to backup my calendar, notes & reminders (they are only in Icloud), but can’t find how to do that and Sugar Sync support hasn’t responded.  I can try them again, but figured I’d see if you have any advice ; ) thanks Donna
          • #2578329
            Yes. still using SugarSync. It does not take the place of Time Machine, ie, it does not backup the System. What it does is sync my data across all my machines MacOS and Windows. I merge the folders across the devices. If I change a file on one device, it is synced across other devices. Some things, like the desktop, I only back per machine. Others I sync selective folders because all the information is not needed everywhere. You can see the devices, an example of a folder merged across devices, and some folders backed only on one device.
            Screenshot-2023-08-07-at-3.43.18-PM
            The advantage is that I can do all my business on my home desktop (an iMac4K running Ventura) in a Windows 8.1 VM, but if I have to travel, all my files are up to date on my M2 MacBook Pro laptop. The Programs I use (Libre Office, Firefox, Adobe Reader, VLC Player, etc) are installed on all devices. So the files are immediately usable. And FireFox syncs my bookmarks, so there you go.
            I backup my VMs en todo once a month. The Macs, I figure I can reinstall the OS without a problem any given a day, as long as my data is safe and will sync back afterward. So far, I haven’t had to reinstall my Macs and I have been using them since 2011.
            • #2578459
              I have a question about the syncing. Is each SS folder actually/physically on your designated device (and not on SS) and so SS manages pointers to your devices’ folders? Or are all of the folders only actually/physically) at SS and so each device has access/pointers to designated SS folders? Basically, where are the files physically – on your devices? or at SS?
            • #2578462
              The synced folders are physically on all drives and physically on SS.
              If the folders only are backed up to SS (not synced), then the folders arephysically on the computer’s drive and only in the folder on SS associated with the device.
              If the folders are synced across devices (merged), then the folders are physically on each device and in a single merged folder on SS.
              See the depiction in the screenshot above. If there is a line across when you highlight the folder on the computer (example in screenshot), the folders are merged and identical everywhere.
              There is none of that “where are the files” and “how do I get them back” s…tuff I read about here for OneDrive.
    • #2358885
      I had an excel file that had several hyperlinks to network directories.
      Just by saving THAT file to OneDrive, it had the wisdom to change ALL the links in the file to OneDrive directories, rather than the network ones!
      There’s a setting in one-drive to stop it doing that (can’t recall it off-hand at the mo), and then it left them alone. Boggling I had to research and set that though. Why the heck would I want it to just blast through all my folders and update links to ones that don’t exist?
    • #2358870
      Hi,
      There is an official way to change the location for the local OneDrive repository.
      Pls see:
      https://support.microsoft.com/en-us/office/change-the-location-of-your-onedrive-folder-f386fb81-1461-40a7-be2c-712676b2c4ae
      Regards
      Bengt Karlsson, Sweden
      • #2362283
        I’ve been doing that successfully for quite some time.
        TIP (for all): if you need to reinstall desktop OneDrive, be aware that OneDrive setup does not seem to check any previous install location information. Ensure you change location to your alternative as your set up during reinstallation.
    • #2358950
      I, like many, have used all of the iterations of OneDrive mentioned in this article. There are certain applications for it which I find it quite useful (although I use Resilio for major Windows file synchronization). Three applications I use OneDrive for in particular: sharing files with others, OneNote notebook synchronization, and syncing my password manager file across platforms.
      But the reason I write is to note the incongruity in two newsletter articles this week. In this one the solution is to use symbolic links, where as in the later article “All storage is not created equal” by Will Fastie, he points to https://support.microsoft.com/en-us/office/restrictions-and-limitations-in-onedrive-and-sharepoint-64883a5d-228e-48f5-b3d2-eb39e07630fa?ui=en-US&rs=en-US&ad=US&mc_cid=e07ab388a3&mc_eid=b26cf2e144#invalidfilefoldernames
      which explicitly states “OneDrive doesn’t support syncing using symbolic links or junction points.” Like many things in Windows, it probably works until it doesn’t… I’m guilty of using things which aren’t documented or I used and they work but in some release they don’t work right anymore and I have to figure out a new way. Ah, Windows…
      [edited to add OneNote synchronization – this is really important to me!]
      • This reply was modified 4 years ago by PhilInWA.
      • #2359070
        PhillnWa – Tell us more about Resilio.  Is its free version similar to SugarSync paid?  Syncs across a few devices?
        Are you related to SteveInWa?  (He’s a grumpy ObiHai and GoogleVoice guru.)
        • #2359227
          glnz – No connection with SteveInWa although I have an Obi device and follow his advice. But since you asked…
          This is a bit off topic in this thread but here’s how I use some of the products/services mentioned:
          Resilio Sync (free): I have three desktops and 4 portable devices running Windows (10 but I’ve been doing this since XP). My wife has a desktop and 2 portable devices running Windows. My son and daughter each have a portable device running Windows. All of these sync their Documents folder amongst their devices and my three desktops (and the desktops amongst themselves). On the desktops then I have 11 synchronized folders. Here’s why I do it that way: 1) I use Backblaze on one desktop to backup everything to the cloud (a single license). 2) On 2 desktops I take local image backups thus capturing “everything” for “everyone.” 3) I have ready to run machines with all my data in case of a failure. 4) Resilio can run as a service easily on those desktops. 5) If a machine has multiple users, each user has its own sync process. I used the precursors of Resilio (don’t remember how many) and this method has gradually evolved over time to be quite stable.
          OneDrive: Sync between Windows, Android & iOS for password management and OneNote sync. We use several shared OneNotes to manage our planning. Also, a convenient way to share photos with others.
          Microsoft 365 Business Standard: 2 licenses for Exchange email and desktop Office products. Exchange email makes all these shared devices work between my wife and myself. It is better than any other alternative I’ve found because we’re both very Outlook centric in our workflow. (And Microsoft pricing is very good.)
          I don’t use DropBox (unless someone drags me in to getting something there). I don’t use Google Drive (similar reason and why add other products into the infrastructure!). And I’ve never used SugarSync (or a couple of other sync products I’ve looked at and even tried) because what I have has been very solid. I actually pay for some things I use that are free because they are so good (e.g., Merlin router firmware, KeePass, AskWoody…).
    • #2358981
      When I first started using OneDrive, I moved it to a partition on another hard drive.
      All of my folders/files are still on my PC in their original locations.  OneDrive is simply a backup for those folders/files.  While the OneDrive folder shows lots and lots of files are cloud-only, the actual file is still in its original location on my PC.
      I don’t use OneDrive to store files in the cloud instead of on my PC.  I use OneDrive to backup files in the cloud.  I have six SSD’s in my daily drive totaling 3.75TB of storage, with plenty of free space available.
    • #2359079
      Noticed lately that onedrive gets stupid if you have pst files in your documents folder.. which is where outlook defaults to. I get it, don’t sync outlook to onedrive but really, move your pst file and then have to redo all rules etc. I hate MS!
    • #2359143
      Used to be when I bought a new PC I had to uninstall all the third party bloat software that was included such as security trialware, apps I would never use and the OEM “value added” crap the PC maker included. Now days a lot of that has been replaced by Microsoft’s junk applications that I must go through and uninstall. Especially if you sign in with a Microsoft account. Because it will log you into Mail, Calendar, Skype, One Drive, and the Store. How convenient but for who?  I can understand why some obsess over uninstalling apps like Edge or any other Application. You should be able to uninstall anything you want to on a Windows install. But you can’t and that is something Microsoft doesn’t seem to respect of its users.
    • #2359244
      The symlink points to a folder that has the original files in it, right?
      So, what happens when you access OneDrive via the web on another unrelated device when the device that has the “pointed at folder” is not up and running?   Can OneDrive let you see the files that are in that “pointed at” folder?
    • #2368165
      I implemented the symlink procedure for several of my important folders and it works. However, I’ve noticed that OneDrive doesn’t immediately start looking for changes when I make changes in the targeted folders. It does look for changes at startup, but there are several ways to force it to  start syncing after you’ve made changes. You can right-click the one drive icon and select pause syncing for 2 hours. Then restart syncing. It will then start looking for changes. Another way I’ve used is to put an empty file (call it file1.txt) on OneDrive and then use a batch file to rename it. This also causes OneDrive to look for changes. Here is the batch file:
      @echo off
      C:
      cd C:\Users\<user-name>\OneDrive\
      IF EXIST file1.txt (RENAME file1.txt file2.txt) ELSE (RENAME file2.txt file1.txt)
      Exit
    • #2578471
      I have OneDrive installed (Windows 10 22H2) but never used the drive yet I have 4535 files in : C:\Users\USER\AppData\Local\Microsoft\OneDrive\setup\logs
      Can I disable creating these files ?
    Reply To: OneDrive, several problems
