When I try to Insert|Quick Parts to access Autotext that I have created I get an error message (see attached).
Sometimes, even though I get the error message, it lets me insert Quick Parts. Sometimes it doesn’t.
How can I repair this so it functions correctly? It is driving me crazy.
Thanks in advance for your advice,
Georgette Grossman
Office 2010, problem with Building Blocks.dotx
Home » Forums » AskWoody support » Productivity software by function » MS Word and word processing help » Office 2010, problem with Building Blocks.dotx
- This topic has 9 replies, 5 voices, and was last updated 9 years, 3 months ago.
AuthorTopicWSGeorgette
AskWoody LoungerDecember 30, 2012 at 6:03 pm #487045Viewing 1 reply threadAuthorReplies-
WSPamCaswell
AskWoody LoungerDecember 30, 2012 at 7:18 pm #1365411~$ilding Blocks.dotx is an owner file, a type of temporary file that Word creates when a document or template file is reopened and ordinarily deletes when the document/template is closed. If Word is unable to close properly, such as when a power failure occurs, the owner file will be left behind and cause problems.
With Word closed, go to the building blocks folder for your version of Word (14 is for W2010) and language (1033 is for US English) in the following example:
C:Users[username]AppDataRoamingMicrosoftDocument Building Blocks103314
and delete ~$ilding Blocks.dotx–but not Building Blocksdotx or Built-In Building Blocks.dotx.
WSGeorgette
AskWoody LoungerJanuary 1, 2013 at 10:23 pm #1365664 -
WSPamCaswell
AskWoody LoungerJanuary 2, 2013 at 9:03 am #1365788 -
WSparker.steve
WSEivind
AskWoody LoungerJanuary 6, 2016 at 9:52 am #1545279~$ilding Blocks.dotx is an owner file, a type of temporary file that Word creates when a document or template file is reopened and ordinarily deletes when the document/template is closed. If Word is unable to close properly, such as when a power failure occurs, the owner file will be left behind and cause problems.
I have a possible related problem. I recently installed Office 365 on a new PC, running Windows 10. When I try to insert a text box into a blank Word document, I get the following error message (translated from Norwegian):
“Word cannot open this document template.
(C:…16Built-In Building Block.dotx)”
I tried the suggestion above, without success.
I have no problems inserting text boxes in e.g. Powerpoint.
Any suggestions? -
Charles Kenyon
AskWoody LoungerJanuary 6, 2016 at 9:30 pm #1545426I have a possible related problem. I recently installed Office 365 on a new PC, running Windows 10. When I try to insert a text box into a blank Word document, I get the following error message (translated from Norwegian):
Any suggestions?Powerpoint does not use building blocks, AFAIK. Try, with Word closed, moving the building blocks templates to a completely different location like your documents folder. Word should regenerate them.
http://www.addbalance.com/usersguide/autotextautocorrect.htm
http://www.addbalance.com/word/pagenumber10.htm -
WSEivind
AskWoody LoungerJanuary 7, 2016 at 2:16 am #1545438Powerpoint does not use building blocks, AFAIK. Try, with Word closed, moving the building blocks templates to a completely different location like your documents folder. Word should regenerate them.
http://www.addbalance.com/word/pagenumber10.htmThank you, that did the trick! I had tried to rename the files within the same folders, but it was obviously neccessary to actually remove them physically.
Charles Kenyon
Charles Kenyon
AskWoody LoungerFebruary 14, 2014 at 1:21 pm #1438983Word 2007 puts its file in the 1033 folder directly. Word 2010(14) and 2013(15) put them in the 14 and 15 folder, respectively. I believe all of them will read and use building blocks in .dotx files that are higher in the file hierarchy than their own file, up to the Document Building Blocks folder. I have the Animated Text Effects.dotx in the “Document Building Blocks” folder and it is used by all of these versions.
If you have multiple versions of Word you will have multiple files. Word 2010 and 2013 each seem to also create a “Building Blocks.dotx” file of their own but I do not know what this is for.
Viewing 1 reply thread -
7 hours, 3 minutes ago -
7 hours, 31 minutes ago -
Security fixes for Firefox
3 hours, 51 minutes ago -
8 hours, 54 minutes ago -
17 hours, 59 minutes ago -
8 hours, 59 minutes ago -
15 hours, 1 minute ago -
WSDavidO61
19 hours, 6 minutes ago -
PeachesP
6 hours, 26 minutes ago -
The local account tax
1 hour, 14 minutes ago -
1 day, 7 hours ago -
23 hours, 32 minutes ago -
MP Support
1 day, 23 hours ago -
16 hours, 59 minutes ago -
Replacing Skype
19 hours, 9 minutes ago -
1 day, 17 hours ago -
nhsj
15 hours, 5 minutes ago -
SheltieMom
18 hours, 55 minutes ago -
3 days, 23 hours ago -
4 days, 1 hour ago -
Peobody
2 days, 13 hours ago -
LarryK
4 days, 2 hours ago -
Serge Carniol
4 days, 17 hours ago -
1 hour, 23 minutes ago -
Inetpub can be tricked
3 days, 4 hours ago
