• Null problem (XP/2K)
    I have the following line of code:
    !curFixedAmount = Me.curPriceShekF + Me.curPriceShekM + (fGetYatzig() * Me.curPriceDollF) + (fGetYatzig() * Me.curPriceDollM)
    the me.* are unbound text boxes that can be null.
    the function fgetyatzig gets the exchange rate from NIs to $ from a table.
    If one of the text boxes is blank then I get the following error:
    “Run time error 13 type mismatch”
    How can I use the NZ function to get rid of this ? I have tried to use it and it does not help.
    Any ideas??
    • #691658
      You probably need to wrap each occurence in NZ()
      !curFixedAmount = NZ(Me.curPriceShekF) + NZ(Me.curPriceShekM) + (fGetYatzig() * NZ(Me.curPriceDollF)) + (fGetYatzig() * NZ(Me.curPriceDollM))
      HTH
      Peter
      • #691659
        I had tried and it did not help, but to be sure I tried what you had written and that also did not work.
        thanks for the try.
        • #691662
          Does this work? It is almost the same as Peter’s solution, but explicitly sets the value to be used instead of Null.
          !curFixedAmount = NZ(Me.curPriceShekF, 0) + NZ(Me.curPriceShekM, 0) + (fGetYatzig() * NZ(Me.curPriceDollF, 0)) + (fGetYatzig() * NZ(Me.curPriceDollM, 0))
          • #691664
            I am about to leave the office. I will try this later
            Thanks Hans
          • #691780
            Still the same problem.
            Could it be the field in the original table which is currency cannot deal with this? (Although I cannot think of any reason why!)
            • #691814
              OK, one more thing to try:
              !curFixedAmount = CCur(NZ(Me.curPriceShekF, 0)) + CCur(NZ(Me.curPriceShekM, 0)) + fGetYatzig() * CCur(NZ(Me.curPriceDollF, 0)) + fGetYatzig() * CCur(NZ(Me.curPriceDollM, 0))
            • #691958
              YES!!!
              thanks Hans.
              What I learn from this is that each part of the function needs a ccur, and not a general one around the whole expression. Why?
            • #691961
              The reason is that if any component of the expression equates to Null then the whole expression equates to Null.
            • #691964
              that explains why each part needs a NZ, but why can you not put a CCur around the whole expression?
            • #691966
              I don’t know the explanation for sure, but sometimes NZ results in a string, even if you would expect a numeric result. If that is the case in your database, CCur forces the result to currency.
    Reply To: Null problem (XP/2K)
