PUBLIC DEFENDER By Brian Livingston Most laptop makers are now leaving the NumLock key out of their smaller notebooks. That’s a disaster for people wh
[See the full post at: No NumLock key? Problem solved! Here’s the fix.]
Home » Forums » Newsletter and Homepage topics » No NumLock key? Problem solved! Here’s the fix.
- This topic has 35 replies, 19 voices, and was last updated 1 year, 10 months ago.
AuthorTopicB. Livingston
AskWoody MVPMay 22, 2023 at 2:44 am #2560887Viewing 21 reply threadsAuthorReplies-
Rick Corbett
AskWoody MVPMay 22, 2023 at 4:07 am #2560903I don’t understand why the article includes a download link for AutoHotkey 2.0.2 pointing to OlderGeeks.com rather than to AutoHotkey‘s own website, where a plethora of help and support is also available.
Newsletter EditorMay 22, 2023 at 1:34 pm #2561050I don’t understand why the article includes a download link … to OlderGeeks.com
Because we have a relationship with them. We know how zealous the McElveens are about assuring the safety of downloaded software and thus consider using those links a comfort to those tentative about freeware. OG always provides the author’s site (if one remains), so anyone can trace back to it.
Rick Corbett
AskWoody MVPMay 22, 2023 at 4:38 pm #2561151Because we have a relationship with them.
Whilst I appreciate that, my concern is that the choice of OlderGeeks.com over AutoHotkey Foundation LLC for the download inadvertently makes it more difficult for new users of AutoHotkey.
The download link on the AutoHotkey foundation website links to a setup.exe file which helps new users by offering choices (including portable installation, if wanted), installs the appropriate version of AutoHotkey automatically and provides an info dashboard.
By comparison, the download link on OlderGeeks.com is to a ZIP file with no information about how to use it.
AskWoody PlusMay 22, 2023 at 4:41 am #2560907Windows 10 tip: Access symbols, emojis, and other special characters
Entering special characters, including foreign currency symbols, fractions, and emoji, is a cumbersome task on most physical keyboards. Use this hidden Windows 10 option to open an on-screen keyboard that puts all those characters at your fingertips…
HenryW
AskWoody PlusMay 22, 2023 at 8:57 am #2560957Uh, Brian, please don’t tell my Unicomp (Part #: UB4TP4A) keyboard that it’s not a US-International keyboard. It will get very upset, ’cause it is.
Seriously, I switched to US-International layouts years ago, because, well, of the additional characters available on it, that aren’t on the standard keyboard. I hope to never have to return to the US standard keyboard layout……
dvhirst865
AskWoody MVPMay 22, 2023 at 1:27 pm #2561047A method, which I use, is to open: https://www.alt-codes.net/ within a browser tab and leave it open then just click on the symbol required and paste to the document. There are many symbols to use on this site with codes available.
Useful if you prefer using a mouse over a touchpad with no app/ program required. ♥ ♫ ♪Windows - commercial by definition and now function...4 users thanked author for this post.
Still Anonymous
AskWoody PlusMay 22, 2023 at 1:30 pm #2561048This one is a fascinating topic. I find it interesting that the only European language that uses Latin scripting and no diacritical characters (or other special characters) is US English. And of course, many of the standards we work with come from American development
My employer works in a multi-lingual environment, and we do some amount of work with bootable media that is password-protected. We’ve discovered that the only non-alphanumeric character that is usable for a password on any computer is physical space. Everything else may vary in location, depending on language. I believe that comes from BIOS that assume US English until a language-specific keyboard driver is loaded.
One other possible use of special characters would be passwords. Not all password systems will accept 8-bit ASCII, and as noted, if you have a keyboard that doesn’t have a NumLock, that’s a problem, but if you put something like ¢ in a password, that’s going to make it far more difficult to crack a password, where both brute-force and dictionary attacks probably don’t anticipate values above ASCII 127.
Norio
AskWoody LoungerMay 22, 2023 at 5:14 pm #2561163I’ve been using WinCompose (https://github.com/samhocevar/wincompose), which has many intuitive features, both portable and installer modes, and an assignable compose key (default is the right <Alt> key). However, this looks like it might be easier to use, especially as I am familiar with AutoHotKey — thanks, Brian!
Ricard
AskWoody PlusMay 22, 2023 at 6:21 pm #2561172This is brilliant, and I’ll use it for any of my programs other than WordPerfect.
I will note that WordPerfect has a similar method built in for special characters, using most of the same combinations as your Quick Keys, triggered by the Ctrl-W keystroke — one of the many reasons that I vastly prefer WordPerfect over MS Word.
I may, however, remap that feature from Ctrl-W to your Backquote key, which seems much easier to type in a line of text.
(One minor advantage to Word is the Shift-Enter keystroke for a line break, which requires Ctrl-Shift-L in WordPerfect. WordPerfect can remap most keystrokes, but NOT those using Enter. But this also has been fixed with the “remarkable AutoHotKey”, which can.)
Thank you.
Win 7 Pro, 64-Bit, Group B ESU,Ivy Bridge i3-3110M, 2.4GHz, 4GB, XP Mode VM, WordPerfect -
georgea
AskWoody LoungerMay 22, 2023 at 6:59 pm #2561183AHK is great, but a real simple, easy to use key remapper [only uses the registry] is
https://www.randyrants.com/category/sharpkeys/
https://github.com/randyrants/sharpkeys
I use it to add a “right click” key on my laptop.
Newsletter EditorMay 22, 2023 at 7:22 pm #2561184Whilst I appreciate that
I prefer to “front” freeware with a reliable source. I think there are basically three kinds of original sources — ones you can absolutely trust because you have familiarity; ones whose Web presence is, shall we say, marginal; and ones that no longer exist.
OlderGeeks injects a level of trust in them all.
Besides, our audience is savvy enough to look at these things carefully. I dare say that most will find the resources at the AHK site. After all, we did provide a link to the AHK documentation at the AHK site in the article.
Save_Us_from_MS
AskWoody LoungerMay 23, 2023 at 1:45 am #2561238Whilst I appreciate that
Maybe I am not old enough or geeky enough, but I have never heard of OlderGeeks before. (I know MajorGeeks)
ibe98765
AskWoody PlusMay 23, 2023 at 2:12 am #2561245I use a very old freeware program from a now apparently defunct website called Map Of Char. I put the link to the program in my taskbar quick launch area (yes, I still use and love QL!). When I need a special char, like a degree symbol ° (Alt-0176), I open the program, click on the symbol and it shows me the Alt-number combo I need to enter. Easy peasy.
Autumn Lesoch
GuestMay 23, 2023 at 7:08 am #2561279 -
Rick Corbett
AskWoody MVPMay 23, 2023 at 10:20 am #2561332Maybe I am not old enough or geeky enough, but I have never heard of OlderGeeks before. (I know MajorGeeks)
OlderGeeks is, IMO, a really-well curated repository of all those teeny-weeny utilities you never knew you needed… until you tried them and suddenly thought – why didn’t I know about this before?
For example, I never knew about a streaming audio service fronted by a UI called Pocket Radio Player… but I now use it almost every day to listen to MY favourite sounds.
I must admit that I avoid MajorGeeks as it continues to play fast and loose with the efforts of others without any accreditation. Just search for MajorGeeks here on AskWoody… no doubt my previous comments (rants) will surface, for example: Why I never link to MajorGeeks. It’s just me… I believe in crediting the original authors of code/reg/whatever that I use as a basis for my own (poor) efforts.
geekdom
AskWoody_MVPMay 23, 2023 at 10:52 am #2561340Why I never link to MajorGeeks
accesses a thread in Moderator Forum and that thread is not available if logged out or a regular user.
WSmchldpy
AskWoody LoungerJune 27, 2023 at 10:02 pm #2569332at Rick Corbett,
I acknowledge that the reason for starting OlderGeeks (because of fake download links, Ads and Crapware as stated in their Mission Statement) was and still is a good thing but users should be aware of/reminded of the dangers of using outdated or no longer developed software. In Backup Utilities (the only category I checked recently) of the 40 offerings half have not been updated in over 2 years and as far back as 2018. Safe to download Software and a Safe Environment to do so does not mean that any software on the site is safe. While this scenario can exist anywhere and OlderGeeks does include Last Updated information on almost every piece of software (newer) users seem to get ‘Safe to Download’ and ‘Safe Software’ confused. Those people also believe Star Trek was actually filmed “On Location”.
btw –
Softpedia over Major Geeks
AusJohn
AskWoody PlusMay 24, 2023 at 6:22 am #2561530I found the article really interesting, and would like to use the Auto Hotkey system on a laptop where I don’t have the luxury of a numeric keypad.
However, I’m a little lost.
I mainly have a need for this type of utility for adding Alt-0xxx symbols (such as Alt-0179 °, Alt-0149 •, etc.) to documents, but there aren’t any such examples in Brian’s .ahk file.
Would some kind soul be able to give me a couple of examples of how I can accomplish this?
AskWoody MVPMay 24, 2023 at 11:17 pm #2561737Thank you for your interest. There is a blue-and-tan “cheat sheet” in the article and in the downloadable ZIP file. It shows most of the glyphs that Brian’s Quick Keys can produce. To enter the degree and bullet symbols you mentioned, see the following line in the cheat sheet:
Backquote @ a A b or o — to enter å Å (Aring) • ° (degree)
The AutoHotKeys script uses Unicode hex values, not the Alt+nnnn system that Windows used on the numeric keypad. I think Backquote @ o is easier to remember to make a degree symbol than Alt+0176. I selected the “@” symbol for this key sequence because it is round, like the circular shapes of the Aring, bullet, and degree characters.
AusJohn
Rick Corbett
AskWoody MVPMay 24, 2023 at 11:32 am #2561613accesses a thread in Moderator Forum and that thread is not available if logged out or a regular user.
You’re absolutely correct. My mistake.
XianAlbar
AskWoody PlusMay 25, 2023 at 9:00 am #2561776I have used Microsoft Keyboard Layout Creator (aka MSKLC) (https://www.microsoft.com/en-us/download/details.aspx?id=102134) to program a similar set of dead keys / key-combinations.
MSKLC generates a Keyboard Layout setup/DLL that one then installs in the Language section of the Windows Settings. It works at the level of the keyboard and is thus accessible to all software.
Attached: source and documentation files.
AusJohn
Rick Corbett
AskWoody MVPMay 25, 2023 at 3:44 pm #2561882Would some kind soul be able to give me a couple of examples of how I can accomplish this?
I have difficulty remembering hotstrings so I use flyingDman‘s AutoHotkey script that displays a character map onscreen to select characters. I’ve highlit the two you mentioned:
I’ve attached the AHK script as a ZIP file in case of any issues with forum encoding. The AHK script is as follows:
var = ÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÑÒÓÔŒÕÖØÙÚÛÜßàáâãäåæçèéêëìíîïñòóôœõöøùúûüÿ¿¡«»§¶†‡•-–—™©®¢€¥££¤aß?de??????µ???p?s?t?f???G?T???SF?O???v-±8˜?=?==×·÷?'??‰°?ø?n?????¬???????????°0123456789°¹²³45678? f12:: w:=20, cnt := 14, arr := strsplit(var) gui, new gui, -caption gui, margin, 0,0 gui, font, s10 loop,% arr.count() { x := mod((a_index - 1),cnt) * w, y := floor((a_index - 1)/ cnt) * w gui, add, text, x%x% y%y% w%w% h%w% center vz%a_index% ginsert,% arr[a_index] } gui, show return insert: gui,submit send % arr[substr(A_GuiControl,2)] return esc:: exitapp
Note that once you run the script, F12 is used to invoke the character map GUI and ESC to dismiss the dialog. (Both these hotkeys can be changed.) The script can be used with Notepad, Word, etc… anywhere that accepts character input.
Basically, the first line of the script creates an array then this array is looped through to create the GUI. Amend the first line if you only need a few special characters.
Note: This script was written long before AutoHotkey 2.0 was released. I’m still using AutoHotkey 1.1.
ibe98765
Newsletter EditorMay 26, 2023 at 5:52 am #2562000There is an error in the column. Next to the “cheat sheet” image under the heading “The fix is here …”, a parenthetical states:
from a command line, enter shell:startup to open the Startup folder
The correct procedure is to enter shell:startup in the Windows Run dialog, which as we all know can be launched in two ways:
- Right-clicking the Start button and selecting Run from the menu, or
- Using the shortcut Winkey+R.
Then enter shell:startup and press Enter. The currently logged-in user’s startup folder will open, into which you can copy the .ahk script. If you wish to add the script for all users of the PC, enter shell:common startup instead.
This is an editing error on my part, for which I take full responsibility. The online version Brian’s column will be corrected in due course.
This reply was modified 1 year, 12 months ago by
Will Fastie. Reason: Typo
Newsletter EditorMay 26, 2023 at 6:18 am #2562008 -
WSmchldpy
AskWoody LoungerJune 27, 2023 at 3:58 pm #2569281I have used the “Alt+number” method list before but IIRC, the Character Numbers were all 4 digits and represented only 1 set, whether it was a Text Character, a Symbol Character or a Wingdings Character. Alt+0169 brought up the Copyright Sign. In the Figure 1 list, “0169” represents 3 Characters. When releasing the Alt key the “©” sign appears but how do I get the Symbol or Wingdings Character associated with 0169 to show up?
I was/am reluctant to ask this because I feel as though it will hurt when it smacks me since the answer is probably located right there in front of my face.
michael
Viewing 21 reply threads -
Trump signs Take It Down Act
6 hours, 6 minutes ago -
6 hours, 32 minutes ago -
7 hours, 40 minutes ago -
Success Knows No End in the World of Online Slots (Awaiting moderation)
isobelhartmann1
7 hours, 49 minutes ago -
not so anon
9 hours, 26 minutes ago -
14 hours, 35 minutes ago -
hibernate activation
e_belmont
18 hours, 21 minutes ago -
22 hours, 8 minutes ago -
2 minutes ago -
Out of band for Windows 10
Giving UniGetUi a test run.
6 hours, 35 minutes ago -
Auto Time Zone Adjustment
wadeer
2 days, 1 hour ago -
Eddieloh
1 day, 22 hours ago -
Mary Branscombe
15 hours, 43 minutes ago -
22 hours, 7 minutes ago -
Apps included with macOS
19 hours, 59 minutes ago -
Xfinity home internet
MrJimPhelps
16 hours, 46 minutes ago -
Debian 12.11 released
2 days, 22 hours ago -
3 days, 1 hour ago -
2 days, 5 hours ago -
Deo
8 hours, 57 minutes ago -
3 days, 18 hours ago -
healeyinpa
3 days, 9 hours ago -
1 day, 6 hours ago
