• Need help with SUM(IF (Excel 97)
    I need a SUM(IF formula that looks at 2 different sets of criteria in order to display a result. I have seen this formula in other spread sheets, but cannot seem to get it to work in my sheet.
    If the date on Sheet2 matches the date on Sheet1, and the value of Sheet2, Column B = 8, then sum column C. I have seen this displayed like {SUM(IF((rdate=pdate)*(inserter=”8″),one))}
    What am I doing wrong?
    • #841320
      How do you want to compare the rdate and pdate ranges? The pdate range contains 30 dates in ascending order, and rdate contains 43 dates in descending order.
      • #841327
        Sorry for the lack of clarity.
        If any of the dates in the rdate column are a match for G3 (in the pdate column, Sheet1). Does this help?
        • #841333
          Sorry, I don’t understand. G3 cannot match any date. Please try to state EXACTLY what you want, perhaps by providing a sample calculation of what the result should be.
          • #841348
            Typo, meant cell A3. I have re-attached the spreadsheet with part of the formula in Cell G3 of Sheet1. I need to add additional criteria to this formula. The result should be 40,584…which is a match for for the date of 06/01/2004, and inserter 8 (from Sheet2, column .
        • #841334
      • #841328
    • #841321
    • #841345
      In cell G3 place this formula.
      =SUM(IF((Sheet2!$A$2:$A$44=A3)*(Sheet2!$B$2:$B$44=”8″),Sheet2!$C$2:$C$44))
      use Ctrl-Shift-Enter to place it because it is an array formula. Copy it down and that should do it for you.
      yoyoPHIL
      • #841353
        Thanks, this is exactly what I needed. Any ideas why it would not work with defined column names?
        • #841359
          It would work if you defined inserter as Sheet2!B2:B44 etc.
        • #841360
      • #841354
    Reply To: Need help with SUM(IF (Excel 97)
