I am using a router at a friends. Staying here for a couple days, so I checked the router on GRC before I started using it. Most of the ports are closed with some open! I logged onto the router and everything looks OK. I’m familiar with the set up because I had a one of same brand. Firewall is set up properly. I turned off UNPNP & WPS. I don’t understand why the public IP address that’s being tested on grc shows closed (not stealth) & open ports. Can somebody help me understand? The Internet service is DSL, I don’t know if that makes a difference.
Need help with GRC Port scan results
Home » Forums » Networking – routers, firewalls, network configuration » Need help with GRC Port scan results
- This topic has 11 replies, 4 voices, and was last updated 3 years, 11 months ago.
Viewing 4 reply threadsAuthorReplies-
Kirsty
Manager -
dmt_3904
AskWoody LoungerJune 23, 2021 at 6:14 pm #2373168There are 3 open ports in a row, five total open ports. Rest are closed except for a couple stealth. But this is interesting – I had done a UNPNP test which came back – No Response. I had not logged onto the router yet and when I did I found UNPNP was not turned off! So is it possible this address is on the ISPs router? Which is still not good but how can it be this router? The firewall is on and when I had tested my router with the same firewall it came back all stealth.
I checked all devices on the network and there are two I don’t recognize. The MAC addresses are: Delta electronics and Espessif. I don’t know what Delta is. Espressif is a Chinese company that provide chips for IoT and Wi-Fi devices.
ek
Paul T
AskWoody MVP -
dmt_3904
Paul T
AskWoody MVP -
dmt_3904
Paul T
AskWoody MVP -
dmt_3904
AskWoody LoungerJune 26, 2021 at 11:41 am #2373733Linksys Velop mesh. I logged in via web, not Linksys app. I think remote access would be off. My Linksys had no explicit option for that, I believe it would be on if you created an online account.
Yes, admin password for router was changed.
Also to your prior question, I had looked at all online devices on the network to identify them. I didn’t check the ip addresses. There were a couple devices that were unknown, I was able to identify the manufacturer with the MAC address – Espressif IoT devices and Delta electronics – I figured they were some IOT devices like maybe the access points for the router.
Or the toaster : ) ha ha ha just kidding
I will be going back there in a couple weeks and can check things again. Donna
Paul T
AskWoody MVP -
dmt_3904
AskWoody LoungerJune 27, 2021 at 6:52 am #2373887All devices on the network will have the same IP address – the router IP address.
oh yeah, right! UNPNP is off. My first GRC test said it was off. Then when I logged into the router, it showed it was on. I turned it off and retested, but no change in the port test results. These results are confusing to me, I don’t understand. I’ll test again when I am back there. Thanks for your suggestions. Donna
Viewing 4 reply threads -
crown
7 hours, 37 minutes ago -
jkitc
10 hours, 16 minutes ago -
Botswana12
11 hours, 1 minute ago -
38 minutes ago -
23 hours, 13 minutes ago -
Dave Easley
16 hours, 32 minutes ago -
gtd12345
Another test post
gtd12345
wadeer
1 day, 7 hours ago -
Limit on User names?
BitLocker rears its head
8 hours, 13 minutes ago -
Who are you? (2025 edition)
7 hours, 10 minutes ago -
1 day, 23 hours ago -
Woody
Scott
2 days, 8 hours ago -
Davidhs
7 hours, 50 minutes ago -
2 days, 22 hours ago -
MS Office 365 Home on MAC
MickIver
2 days, 16 hours ago -
3 days, 12 hours ago -
J9438
7 hours, 35 minutes ago -
4 days, 7 hours ago -
3 days, 11 hours ago -
dmt_3904
Login screen icon
3 days, 2 hours ago -
AI coming to everything
17 hours, 3 minutes ago -
4 days, 23 hours ago -
No Screen TurnOff???
BigDaddy07
3 hours, 57 minutes ago
