I was looking on the net for ways to update the users FE and came across the following code which I have tried to adapt for my needs
Dim WSHShell Dim appAccess ‘ Current Access application window Dim fso ‘ FileSystem object used to access files ‘Dim DesktopPath ‘ Desktop folder, where shortcut is placed Const iButtonTypeOK = 0 ‘ Popup controls Const iIconTypeStopMark = 16 Const iIconTypeQuestionMark = 32 Const iIconTypeExclamationMark = 48 Const iIconTypeInformationMark = 64 Dim intButton Const iOKButtonClicked = 1 Const iButtonsNotClicked = -1 ‘Const strONEfilename = “%USERPROFILE%DatabaseJob Management 2007” Const strONEfilename = “C:UsersAllanDatabaseJob Management 2007” Const strONEfolder = “r:” Set WSHShell = CreateObject(“WScript.Shell”) Set fso = CreateObject(“Scripting.FilesystemObject”) ‘ Warn the user that updating is about to occur. ‘ (A 10 second delay is added. With a slow network connection, somehow this ‘ helps to avoid the automatic update from being launched a second time.) While intButton iButtonsNotClicked intButton = WSHShell.PopUp(“W A I T ! Don’t click the button!” & vbCrLf & vbCrLf & “ONE is about to be automatically updated. Please wait while the new version is loaded–then you will see another alert dialog.”, 10, “Automatic Update of ONE”, iButtonTypeOK + iIconTypeStopMark) Wend ‘ First stop the current Access program, then copy files from the ‘ ONE folder to the C: drive, then launch the new program in the same ‘ application window. On Error Resume Next ‘ Detect if ONE is running (from the proper folder) by an indirect method: ‘ If the LDB file cannot be deleted then the MDB file is probably opened. ‘ Trap the error accordingly. fso.DeleteFile “C:UsersAllanDatabaseJob Management 2007.laccdb” ‘fso.DeleteFile strONEfilename & “.laccdb” If Err.Number = 70 Then ‘ LDB file cannot be deleted, so ONE is running as expected. On Error GoTo 0 ‘ Close down the instance that called this script Set appAccess = GetObject(strONEfilename & “.accdb”) appAccess.CloseCurrentDatabase ‘ Update ONE On Error Resume Next fso.CopyFile strONEfolder & “Job Management 2007.accdb”, strONEfilename & “.accdb” If Err.Number = 0 Then ‘ Announce that ONE has been successfully updated WSHShell.PopUp “Your ONE program has been updated.” & vbCrLf & vbCrLf & “Click the button to launch ONE.”, 0, “Automatic Update of ONE”, iButtonTypeOK + iIconTypeInformationMark ‘ Launch the updated program in the same Access window appAccess.OpenCurrentDatabase strONEfilename & “.accdb” ‘ Done !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ElseIf Err.Number = 76 Then ‘ The ONE file server folder is not available. ‘ Leave Access open with no program running. WSHShell.PopUp “The copy script cannot update your program, probably due to an intermittent network problem; it failed with error ” & Err.Number & “: ” & Err.DESCRIPTION & ” !!!”, 0, “Automatic Update Failure”, iButtonTypeOK + iIconTypeInformationMark ‘ Done !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Else ‘ Unexpected error WSHShell.PopUp “The copy script failed with error ” & Err.Number & “: ” & Err.DESCRIPTION & ” !!! Please report this error and do not continue using the program !!!”, 0, “Automatic Update Failure”, iButtonTypeOK + iIconTypeExclamationMark ‘ Done !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! End If Else ‘Perhaps the script was launched in another way, ‘or the user has already closed ONE. WSHShell.PopUp “The copy script failed with error ” & Err.Number & “: ” & Err.DESCRIPTION & ” !!! If this happens again then please report this error and do not continue using the program !!!”, 0, “Automatic Update Failure”, iButtonTypeOK + iIconTypeExclamationMark End If
the original code comes from this thread item 5.
Questions and problems.
Does this code need to be called from a module? I have tried it behind a button on a form and it shuts the database down but doesn’t continue.
This command fso.DeleteFile strONEfilename & “.laccdb” will not run as %USERPROFILE% is not understood by the command. Is there a way to read this earlier or to read the current database file location so that the script will work for different PCs?
