• Need Help with automatical copy, paste then sum (Exel 2000)
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Need Help with automatical copy, paste then sum (Exel 2000)
    I’ve been bashing my head trying to get excel to copy from sheet 1 to sheet 2 and them automatically sum at the end of the last cell.
    I’m trying to remove as much of the manual labor involed in moving information from worksheet to another. So I would like to find out if it is possible to do the following.
    I have a worksheet (sheet 1) in workbook 1 that contains item Name in colunm A, Quantity in colunm B, and Ext Cost in colunm C, all of this information is pasted from another workbook, workbook2 . I also have a worksheet that is titled Manifest in workbook 1, I would like to copy all of the information in colunm A and colunm B automatically from sheet1 of workbook 1 into the worksheet titled Manifest of workbook 1, then some how have it sum colunm C automatically which will always have different number of row.
    Is there any possible way using a macro or VBA to accomplish this process?
    • #625220
      If I interpret your description properly – try this as an event procedure on the manifest sheet.
      It should accomplish the copy each time you enter the sheet.
      Private Sub Worksheet_Activate()
      ActiveSheet.Cells.ClearContents
      Worksheets(“Sheet1”).Range(“A:B”).Copy _
      Destination:=ActiveSheet.Range(“A:B”)
      i = ActiveSheet.UsedRange.Rows.Count
      ActiveSheet.Cells(i, 3).Formula = “=SUM(Sheet1!C:C)”
      • #625888
        Andrew, you were right on the money. Your script worked as it should. But I do have a question what if I wanted to start pasting the information over into cells A13:B13. currently it strat in A1:B1, I ould like to offset this by at least 15 cell down.
        If I’m asking for to much please let me know.
        • #625898
          Try the following where j is the offset – (currently 14)
          ActiveSheet.Range(Cells(14, 1), Cells(ActiveSheet.UsedRange.Rows.Count, 3)).ClearContents
          i = Worksheets(“Sheet1”).UsedRange.Rows.Count
          j = i + 14
          Worksheets(“Sheet1”).Range(“A1:B” & Format(i)).Copy _
          Destination:=ActiveSheet.Range(“A14:B” & Format(j))
          ActiveSheet.Cells(j, 3).Formula = “=SUM(Sheet1!C:C)”
          Note that the routine fully cleared the sheet prior to loading – this was a quick method.
          I assume you’re trying to preserve the first fourteen rows and am therefore only clearing columns A:C from 14 down to the EXISTING last cell
          Andrew
          • #626277
            Andrew, you did it again, this worked perfectly.
            Thank you very much for your help.
            W.R.
    Reply To: Need Help with automatical copy, paste then sum (Exel 2000)
