I posted this over at the Win2000 forum and am not getting any response. Since this issue is handled the same in Windows XP I thought I’d post here as well and see if anyone knows about these “Ne01 etc.” port settings.
Each printer on a USB port is assigned an “Ne#” addresss, such as “Ne01”, “Ne02” etc. This does not seem to relate directly to the USB port number, such as “USB001”, “USB002” etc. These “Ne#’s” can be seen if you created an Excel macro to print to a USB printer and then edit the macro.
My problem is that if I add another item to a USB port all these “Ne#”s” change. I have numerous Excel macros that automatically print to my various printers (4 are on the system) and all these macros have to be edited if the “Ne#’s” change….and they do if I add another USB device to the system.
Does anyone know of a way to adjust the “Ne#’s” …… hopefully similar to changing a printer port assignment under CONTROL PANEL, PRINTERS. If so, then I could edit the “Ne#’s” instead of all my macros each time this occurs.
Thank you,
BH DAvis
