As the title says, Check for Updates in any and all of the Office applications on my PC does not work. Going to Help, “Check for Updates” in Word, Excel, Outlook and Access all do exactly the same thing: Nothing. Which ever application is running just sits there. Windows XP’s “Check for Update” works fine. Norton Internet Security 2003’s “Live Update” works fine. It has been this way since Dell sold me a Dimension 4600 preloaded with Windows XP SP1 and Office 2003 Pro. Can any out there tell me what to turn on so it will work?
My Office2003 Pro Check for Updates does not work (Office 2003 Pro)
Home » Forums » AskWoody support » Productivity software by function » Productivity software by function – other » My Office2003 Pro Check for Updates does not work (Office 2003 Pro)
- This topic has 16 replies, 3 voices, and was last updated 21 years ago.
AuthorTopicJohn Littell
AskWoody PlusMay 3, 2004 at 10:33 pm #404459Viewing 1 reply threadAuthorReplies-
DaveA
AskWoody_MVP -
John Littell
AskWoody PlusMay 4, 2004 at 3:44 pm #823169DaveA, Thank you for the suggestion. Here’s what I did: 1) I turned on the Windows XP Internet Connection Firewall (Norton recommends that ICF be turnoff when its firewall is active), 2) I turned off the Norton Internat Security 2003 firewall, 3) I left the Belkin DSL Router in the loop as “Check for Update” was dead long before this hardware was added, 4) I ran Word2003, “Check for Update”, Nothing. Please try again.
John -
DaveA
AskWoody_MVPMay 4, 2004 at 3:50 pm #823179Why are you using “Windows XP Internet Connection Firewall ” if you have Norton’s?
You should be able to tell Norton’s that it is safe for the Office update to have Internet access. You may also be blocking any script file that may be running to get to the Internet.
The Windows XP Internet Connection Firewall may be blocking the access. I do NOT use CF from MS, I use ZoneAlarmbe.
Genealogy....confusing the dead and annoying the living -
DaveA
AskWoody_MVPMay 4, 2004 at 3:50 pm #823180Why are you using “Windows XP Internet Connection Firewall ” if you have Norton’s?
WSRebel
AskWoody LoungerMay 4, 2004 at 4:04 pm #823187John,
If you connect directly to the Office Update Site (through Internet Explorer rather than using the Help menu from within an Office application) are you able to check for updates correctly? -
John Littell
AskWoody PlusMay 4, 2004 at 4:30 pm #823203John,
Yes, connecting directly to the Office Update site worked. I needed updates to Outlook2003 and Excel2003. Now I just have to remember to connect manually on occasion. And, further suggestions as to why “Check for Update” does not work are no longer critical, but I’d sure like to know why something I payed for does not work.
Thanks to all again, John -
WSRebel
AskWoody LoungerMay 4, 2004 at 4:37 pm #823209Well that’s good. If this is working, then I suspect that the non functioning “check for updates” from within an Office application may have something to do with your internet connection (either router or modem). Just for interest, fire up a connection (from Internet Explorer) and then open Word and try again from the Help menu. Let us know if it works.
John Littell
AskWoody PlusMay 4, 2004 at 5:40 pm #823243John,
I tried your suggestion: connected to the officeupdate site, broght up Word, and Nothing. I thought it possible that the problem started when I switched to DSL six months ago so I called my ISP tech support guy to see if any kind of modem setting could be blocking it. He said no, that the problem was probably Microsoft’s and would be fixed soon. (Brand X pointing to brand Y.) Not likely, something like this would not go unreported. So now I’m left with the problem probably starting eight months ago when I upgraded to this PC and Office 2003. (Sorry about the rambling.)I’m again not panicing but I’m out of ideas. John
WSRebel
WSRebel
John Littell
AskWoody PlusMay 4, 2004 at 5:40 pm #823244John,
WSRebel
AskWoody LoungerMay 4, 2004 at 4:37 pm #823210Well that’s good. If this is working, then I suspect that the non functioning “check for updates” from within an Office application may have something to do with your internet connection (either router or modem). Just for interest, fire up a connection (from Internet Explorer) and then open Word and try again from the Help menu. Let us know if it works.
John Littell
AskWoody PlusMay 4, 2004 at 4:30 pm #823204John,
WSRebel
AskWoody LoungerMay 4, 2004 at 4:04 pm #823188John,
John Littell
AskWoody PlusMay 4, 2004 at 3:44 pm #823170DaveA, Thank you for the suggestion. Here’s what I did: 1) I turned on the Windows XP Internet Connection Firewall (Norton recommends that ICF be turnoff when its firewall is active), 2) I turned off the Norton Internat Security 2003 firewall, 3) I left the Belkin DSL Router in the loop as “Check for Update” was dead long before this hardware was added, 4) I ran Word2003, “Check for Update”, Nothing. Please try again.
JohnDaveA
AskWoody_MVPViewing 1 reply thread -
2 hours, 3 minutes ago -
No more rounded corners??
4 hours, 28 minutes ago -
Android 15 and IPV6
3 hours, 8 minutes ago -
14 hours, 24 minutes ago -
17 hours, 6 minutes ago -
11 hours, 40 minutes ago -
May preview updates
11 hours, 48 minutes ago -
3 hours, 23 minutes ago -
16 hours, 37 minutes ago -
crown
13 hours, 41 minutes ago -
jkitc
3 hours, 1 minute ago -
Botswana12
2 hours, 59 minutes ago -
2 days, 4 hours ago -
Dave Easley
2 hours, 35 minutes ago -
gtd12345
2 days, 17 hours ago -
Another test post
gtd12345
wadeer
2 days, 12 hours ago -
Limit on User names?
2 days, 15 hours ago -
2 days, 5 hours ago -
BitLocker rears its head
Who are you? (2025 edition)
2 days, 7 hours ago -
3 days, 4 hours ago -
Woody
Scott
3 days, 13 hours ago -
Davidhs
4 days, 3 hours ago -
MS Office 365 Home on MAC
MickIver
3 days, 21 hours ago -
4 days, 17 hours ago
