Reporting information that is NOT there is always a challenge. The only thing I can think of is to create a Dates table that includes the dates you want, and then use an Outer Join to link it to your regular table, based on date. I can remember if this is a right or left outer join, but essentially you want every date from the Dates table, plus any matching records from your regular table.
More SQL Help (97 SR2)
Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » More SQL Help (97 SR2)
- This topic has 5 replies, 4 voices, and was last updated 23 years, 6 months ago.
AuthorTopicWSMarkLiquorman
AskWoody LoungerSeptember 28, 2001 at 1:47 am #360889Viewing 1 reply threadAuthorReplies-
WSKel
AskWoody LoungerSeptember 28, 2001 at 3:08 am #544423Alright, so i’ve got a nice little SQL statement:
SELECT Format(tblmain.DateStarted,"dddd") AS Day, Count(tblmain.DateStarted) AS Entered, Abs(Sum([Status]="Complete")) AS Complete, Abs(Sum([Status]="Pending")) AS Pending FROM tblmain GROUP BY tblmain.DateStarted HAVING (((tblmain.DateStarted) Between Date() And Date()-7));
The problem with this is, if for any reason nothing was entered on a particular day, the resulting query skips right over it. Jumping for example, from monday to wednesday if nothing was entered on Tuesday. This adds irregularity to my report. Is there a way for me to represent that if nothing was done on Tuesday, then the values for tuesday would be Zero?
Thanks!
Edited to eliminate horizontal scrolling–Charlotte
WSralphad
AskWoody LoungerSeptember 28, 2001 at 6:06 am #544500I agree with Mark’s suggestion, I think it’s the correct way to do it.
You’ll want an left outer join from the dates table to the existing table. Something like:-
SELECT Format(tblmain.DateStarted,"dddd") AS Day, Count(tblmain.DateStarted) AS Entered, Abs(Sum([Status]="Complete")) AS Complete, Abs(Sum([Status]="Pending")) AS Pending FROM tblDates LEFT JOIN tblMain ON tblDates.DateWanted=tblMain.DateStarted GROUP BY tblmain.DateStarted HAVING (((tblmain.DateStarted) Between Date() And Date()-7));
N.B. in the above example your dates table will be called ‘tblDates’ with a field named ‘DateWanted’ containing the days you want to run your report for…
WSMarkLiquorman
WSKel
WScharlotte
Viewing 1 reply thread -
Nvidia just fixed an AMD Linux bug
1 hour, 26 minutes ago -
50 years and counting
30 minutes ago -
Fix Bluetooth Device Failed to Delete in Windows Settings
Drcard:))
3 hours, 56 minutes ago -
Licensing and pricing updates for on-premises server products coming July 2025
12 hours, 30 minutes ago -
Edge : Deprecating window.external.getHostEnvironmentValue()
12 hours, 35 minutes ago -
Rethinking Extension Data Consent: Clarity, Consistency, and Control
12 hours, 39 minutes ago -
OneNote and MS Word 365
14 hours, 28 minutes ago -
Ultimate Mac Buyers Guide 2025: Which Mac is Right For You?
14 hours, 39 minutes ago -
Intel Unison support ends on Windows 11 in June
14 hours, 52 minutes ago -
April 2025 — still issues with AMD + 24H2
Kevin Jones
15 hours, 3 minutes ago -
Windows 11 Insider Preview build 26200.5518 released to DEV
Windows 11 Insider Preview build 26120.3671 (24H2) released to BETA
Forcing(or trying to) save Local Documents to OneDrive
PateWilliam
1 day, 11 hours ago -
Hotpatch for Windows client now available (Enterprise)
23 hours, 23 minutes ago -
MS-DEFCON 2: Seven months and counting
22 minutes ago -
My 3 monitors go black & then the Taskbar is moved to center monitor
saturn2233
Apple backports fixes
Win 11 24H2 will not install
Michael1950
35 minutes ago -
Advice to convert MBR to GPT and install Windows 11 Pro on unsupported PC
Andy M
1 hour, 53 minutes ago -
Photos from iPhone to Win 10 duplicating/reformatting to .mov
J9438
9 hours, 4 minutes ago -
Thunderbird in trouble. Here comes Thundermail
1 day, 22 hours ago -
Get back ” Open With” in context menus
2 days, 11 hours ago -
Many AMD Ryzen 9800X3D on ASRock have died
simple general stupid question
WSaltamirano
2 days, 9 hours ago -
April 2025 Office non-Security updates
3 days, 2 hours ago -
Microsoft wants to hear from you
2 days, 2 hours ago -
Windows 11 Insider Preview Build 22635.5160 (23H2) released to BETA
3 days, 5 hours ago -
Europe Seeks Alternatives to U.S. Cloud Providers
3 days, 11 hours ago -
Test post
3 days, 13 hours ago -
Used Systems to delete Temp files Gone WRONG what does this mean?
Deo
3 days, 15 hours ago
