• More help with recorded macros
    Folks,
    Right now with the first 3 of an expected 150 two-page tables (to be done by this Friday), I am selecting the topic rows by clicking in the left margin while holding down Ctrl. I then apply the shading macro I recorded. Naturally, I”m looking for a way to skip or reduce about 20 keystrokes. I can use Find or the Styles pane to select all white colored text, but I don’t see a way to change the selection from the text to the cell it is in. Also, the recorder doesn’t record select all instances chosen from the in the styles pane or Find In Document (and select all) from the search dialog.
    Is it possible to record a macro that selects the white type and then expands the selection to the whole row/cell?
    Thanks,
    Pam
    Viewing 7 reply threads
    • #1285895
      Something like this maybe?
      Code:
      Sub ShadeRow()
      Selection.HomeKey wdStory
      With Selection
          With .Find
              .ClearFormatting
              .Font.Color = wdColorRed
              .Text = ""
              .Replacement.Text = ""
              .Forward = True
              .Wrap = wdFindStop
              .Format = True
              .MatchCase = False
              .MatchWholeWord = False
              .MatchWildcards = False
              .MatchSoundsLike = False
              .MatchAllWordForms = False
          End With
          While .Find.Execute
              .MoveEnd wdRow
              .Shading.ForegroundPatternColor = wdColorGray10
              .Collapse wdCollapseEnd
          Wend
          .Find.ClearFormatting
      End With
    • #1285945
      Thanks, Jefferson. That should work, just have to switch to my color, which is specified in rgb. I’ll let you know how I make out.
      Pam
    • #1286029
      Hi, Jefferson,
      The code doesn’t work. The cursor just sits there, and when I open the find dialog, there’s no history of the search. I did change the shading color to rgb. Could that have affected the whole macro?
      Pam
    • #1286106
      Maybe the problem is the in find color match. I got a document today which used a shade of green I literally could not figure out a way to “find.”
    • #1286127
      Reveal formatting (Shft F1) is usually a good bet.
      Today, I’m getting an error message: Invalid or unqualified reference. And it’s pointing to the “While .Find.Execute” line. If I add “Selection” before .Find, the debug(ger?) says the same thing at the next line. Hmmm. Help.
    • #1286176
      Might be an extra End With somewhere above that line.
    • #1286337
      Jefferson: Thanks for your help. On reading your code, I started thinking of doing the task serially instead of in bulk (the way I do it manually). I recorded a macro to do all the steps once. Then I found a do loop within another macro and put it into mine. Works great.
      Thanks again,
      Pam
      Code:
      Sub ShadeHdRows()
      ‘Mostly recorded
          Selection.Find.ClearFormatting
          Selection.Find.Font.Color = -603914241
          Selection.Find.Replacement.ClearFormatting
          With Selection.Find
              .Text = “”
              .Replacement.Text = “”
              .Forward = True
              .Wrap = wdFindContinue
              .Format = True
              .MatchCase = False
          End With
      Do
          Selection.Find.Execute
          If Selection.Find.Found = True Then
          Selection.SelectRow
          Selection.Shading.Texture = wdTextureNone
          Selection.Shading.ForegroundPatternColor = wdColorAutomatic
          Selection.Shading.BackgroundPatternColor = 5982208
          Selection.MoveRight Unit:=wdCharacter, Count:=1
      Else
          Exit Do
      Loop
    • #1286485
      I can never work out why Word records the find using a mixture of With Selection.Find and explicitly repeating Selection.Find
      This version of your code tidies up the odd way that Word has recorded your steps and also simplifies the loop somewhat
      Code:
      Sub ShadeHdRows2()  With Selection.Find
          .ClearFormatting
          .Font.Color = 255
          .Text = “”
          .Forward = True
          .Format = True
          .MatchCase = False
          .Execute
          Do While .Found
            Selection.SelectRow
            .Execute
          Loop
          .ClearFormatting
        End With
    Reply To: More help with recorded macros
