• Magellan GPS – Questions, Tips and Help
    Home » Forums » Outside the box » The Junk Drawer » Magellan GPS – Questions, Tips and Help
    I want to start a Magellan GPS forum here at Woody’s. Hearing that the admins do not like people re-posting an article from elsewhere, I have the below links to articles posted as a courtesy.
    My desire is to have people helping one another with Magellan GPS products like we do in the computer sections of Woody’s.
    Magellan 3250 Screen Replacement & Repairs
    https://www.gps-forums.com/threads/magellan-3250-na-touchscreen-replacement-other-repairs.47042/
    Magellan 3250 Maintenance Options
    https://www.gps-forums.com/threads/magellan-3250-maintenance.47045/
    Magellan 3250 has trouble locking onto satellites after Suspend
    https://www.gps-forums.com/threads/magellan-3250-has-trouble-locking-onto-satellites-after-suspend.47048/
    Thank you.
    Moderator note: Moved Topic to “Outside the Box” a forum for non-Windows subjects.
    Viewing 5 reply threads
    • #1918407
      Hello, I have a little more information on the “Magellan 3250 has trouble locking onto satellites after Suspend” problem.
      The problem is Magellan will usually not get satellites upon a short term off (suspend) period. If one holds the off button down for 5 seconds, it turns it off. Turn it back on and it will find satellites within 30 seconds and lock on.
      I have noticed if the list in the satellites acquired screen is short then there is a 99% chance it will not get a satellite lock. If the satellite list has 10, definitely 11 or 12 (full list) then it will get a satellite, then lock on within seconds. I have noticed if the Magellan is in this suspend mode as the car is off, for overnight, the next day it will get a satellite lock just fine.
      The problem is more the short term off cycle. Off for a minute, 15, or an hour, then back in the car and nope, no satellites locked on. Turn off, then back on, its fixed.
      I have had some people say maybe it is the satellites have moved on. Nope, it can have 9 satellites locked on (green) and see 11 total. Turn off the car (suspend mode), restart in a minute or two and Magellan is lost. If it has a short list just “reboot” and save time. We have driven 20 minutes, stopping at stop lights, and still no satellite lock. Reboot the Magellan and its back to normal again.
      Thanks to anyone with an idea.
      • #1918468
        Has anyone called the manufacturer?
        Lifted from here:
        Tip
        If troubleshooting doesn’t fix your Magellan GPS device, contact the company’s technical support line toll-free at 800-707-9971. Technicians are available Mondays through Fridays from 6 a.m. to 5 p.m. PST/PDT.
        • #1918569
          Thank you for your answer it is appreciated. NOPE, I have not called nor expect to call Magellan support.
          1) this 3250 is a 12 year old device and no-one is going to support it at the manufacturing level today.
          2) have you seen some of the comments people have made of the lack of knowledge the support people have reading from script and then saying send it in?
          I have more faith in Woody users having a reasonable suggestion than “manufacturing support” would today.
          Thank you again.
    • #1919666
      Hi anonymous, I am not familiar with the product so I have never experienced the problem. But I think your comment 1918407 contains the clue. “Turn off, then back on, its fixed.”
      This reads as a user error in not powering down the device in the proper manner. Remember twelve years ago was the first iPhone, technology has really changed since then. Even Windows today will give errors if you cut power without initiating a proper shutdown sequence. Shutting off the car by stopping the engine without first turning off the Magellan could give a similar difficulty.
      Test by first operating normally. Then when you park, before turning the key or pushing the OFF button of your vehicle, turn off the Magellan 3250. When it indicates an “off” condition, then stop the vehicle engine as normal.
      If your car also shuts down in idle conditions like a long red light, remember that also was not a feature for most drivers twelve years ago.
      Please post back if this test gave better service, also post if it did not help.
      • #1919683
        Hello Anonymous #1919666 and thank you for your ideas.
        The Magellan 3250 has a “suspend mode” that it went into when power was cut from the unit. In other words it knew the car was turned off and turned itself off (suspend) accordingly. This was never an issue until recently, lets say this year 2019. (We did read where there was a “Y2K” bug in the satellites this year from poor programming. “That’s 20 years from now (2000) no one will know…”)
        GPS Rollover is today. Here’s why devices might get wacky
        https://techcrunch.com/2019/04/06/gps-rollover-is-today-heres-why-devices-might-get-wacky/
        I don’t think ours suffered from that but it is a recent new problem. Today I had some good results with the Magellan, having less than 10 satellites seen and once out in the open it found the satellites, locked on and I had 5 or 6 in 60 seconds. THAT is the way it use to work.
        I will try your suggestion of turning it off first, then shut off the car to see if any difference happens.
        Thank you again.
        • #1921384
          Cutting power supplied to the logic board would create unpredictable results. A suspend mode as you describe would require a small power source to complete the action before suspending then a smaller demand to hold the information state while suspended. I suspect there is an internal battery that has aged very well, but is now more recently showing a weakness. Like the CMOS battery for a laptop.
          Is there documentation that gives direction to replace a “backup” battery? Or is this device completely powered internally, by alkaline or other standard battery designs? I had imagined the unit plugged into the 12V DC outlet, or cigar lighter.
          • #1921411
            Anonymous #1921384 that is a very good idea! I do know that some of the older Magellans of the 1990’s did have an internal battery to keep data, separate from the main battery.
            I changed the battery back last year, and had to swap the touch screens with another “parts” Magellan recently. I did not see any small battery (like a CMOS) inside when I was inside, but I also was not *looking* for any either. However, I do believe if I had seen something like a CMOS it would had caught my eye.
            That was a very good suggestion. If by chance I ever do have to go back inside that Magellan, I will make a special note to specifically look for anything that could possibly be a CMOS battery setup.
            Thank you.
    • #1926636
      Update to the satellite acquisition problem.
      The problem is more the short term off cycle. Off for a minute, 15, or an hour, then back in the car and no satellites locked on. Turn off, then back on (reboot), its fixed.
      I am noticing if the Magellan is in suspend for over 3 hours, it seems to be able to get a lock on. If it is less than that, it will usually fail. These hours off (suspend) are approximate. This is an ongoing evaluation of a problem.
      I also have noticed that certain satellites must have the data Magellan needs. The satellites have a Pseudo number, so they say, and it appears numbers; 10, 12, 13, 20, 22, 25, 29 and 51 have the data Magellan wants. Satellites 05, 11, 14, 15, 24, 27, 32 may not. Just today satellites; 05, 10, 15, 24 struggled for 15 minutes “talking” to Magellan and never locked on.
      Therefore I was curious if anyone knows, are some satellites having issues or have bad data that Magellan can not benefit from, so it fails?
      There is the programming error called the satellites Y2K problem that happened in April of 2019. This was supposed to be a time/date issue. I do not think our Magellan 3250 has an issue with that but it is strange that it can see the satellite, have a “long discussion” with its orange bar displayed, and never get a lock (green bar). Is there a type of handshake similar to a modem connection that data is exchanged and if it is corrupt or wrong, it is ignored?
      Some very good ideas have been offered here. Is anyone out there a GPS satellite communications expert?
      Thanks again.
    • #2018001
      Hello, I am the OP here and have more to add. I have noticed the Magellan has a time frame that is happening with this inability to acquire satellites.
      If the Magellan has been off (suspended) for over 2 hours, it will look for satellites and acquire them in 30 seconds or less. If the Magellan has been off (suspended) for LESS than 2 hours it will fail to acquire satellites, unless a reboot is done. A reboot is to hold the off button down for over 5 seconds. Once rebooted, the Magellan will acquire satellites within 30 seconds and is fine.
      Something has changed over the years with either the Magellan itself, or … maybe the satellites in the sky are responding in a different way and it just has troubles reacquiring the list of satellites just used, but if rebooted it starts fresh and acquires them at that point.
      Thanks to all for responding.
    • #2425982
      Hello, I have a Roadmate 9412T-LM and I tried to perform a map update and there was an issue of insufficient storage. I watched a video where the person went step by step formatting his Roadmate then using an sd card in the unit to fool the website that there was enough space, then installed the update onto the sd card. He then then saved the MAP file onto the pc. after that he formatted the sd card then from Magellan support, downloaded the recovery tool. He extracted, copied and pasted the files onto the sd card. The last step was inserting the sd card back into the unit and turning it on. His unit started booting up with the normal Roadmate logo then it it had him click to start which installs the boot items, the menu’s then it restarted and intalled the rest of the files and he was pretty much all set. I’ve done all the same steps and at the last step after inserting the sd card and powering on, it went to a blue screen  where at the bottom it said reading file please wait and below that was the percentage loading. I noticed it went to 100%, I waited 5 minutes or more but nothing happened so I disconnected it, powered it off, then on where the Magellen logo appears and stays there. If I eject the sd card nothing happens. If I hold the power button down while rebooting, it shuts off. when reconnected to the pc, it is not recognized. I tried to follow every step precisely. If anyone cab tell me where this went wrong and what I need to do to fix it, it would be greatly appreciated?
    • #2426294
      Hello TJMethod, Thank your for posting here. I am the OP and wanted to try and get a Magellan topic going. While I am not a Magellan expert I can say that I saw on the internet another with your Roadmate 9212T-LM having an issue of it being “stuck on” the computer connection.
      Electronics Technician Dustin mentions to go to Magellan’s site and see how to reset your Magellan. It is claimed (at the Magellan site) to hold the power button down for 8 to 10 seconds. If that does not help, then go to http://www.smartgpseco.com and download the Magellan SmartGPS Eco software.
      From there one should be able to have that software inspect your Magellan and download the OS and Maps. At least that is my understanding.
      You might want to investigate https://www.smartgpseco.com/ which is referred by Magellan’s site itself for loading maps. I also want to encourage you to not give up. On the internet another had tried five (5) times to install a map and used two (2) different computers. Then all of a sudden, it just loaded, and was fine.
      I hope this helps you in some way.
      REF:
      How do you reset a Magellan GPS 9212T-LM it is stuck on by Electronics Technician: Dustin 2/13/2016
      https://www.justanswer.com/gps/9jop7-reset-magellan-gps-9212t-lm-it-stuck-connection.html
      I am having a problem with my Magellan Roadmate 9212T-LM… by Electronics Technician: Russell H. 4/2/2017
      https://www.justanswer.com/electronics/abswj-having-problem-magellan-roadmate-9212t-lm.html
    Reply To: Magellan GPS – Questions, Tips and Help
