• KeyScrambler problem
    • This topic has 2 replies, 3 voices, and was last updated 8 years ago.
    QFX Software issued an update a couple of days ago for KeyScrambler, its well known Anti-Keylogging software. Ever since I installed the update I’ve had a problem with my keyboard working when trying to make entries in my browser. Turning KeyScrambler off seems to resolve the problem. This happened on both my Vista and XP computer.
    I’m using the Pro version of KeyScrambler. I couldn’t find any QFX Software forum for KeyScrambler. So I’ll ask over here if anyone else experienced this problem and what, if anything, other than turning KeyScrambler off solved it.
    Al
    • #1385168
      Hi Al,
      I had the same problem and uninstalling/reinstalling the program solved it. Hope it does the same for you.
    • #1594365
      Al
      Same problem here.Uninstalling and re-installing didn’t work for me.In the end I did an Acronis backup restore.(Win 7 64bit)
    Reply To: KeyScrambler problem
