Kaspersky 2010 has been working fine in a Win7 environment but recently stopped. Reinstalled program from CD. All well. Updated definitions. All well. Then responded to prompt to update program to newest version and after that was done it was no longer possible to get the program even to open. Any ideas? Thanks.
Kaspersky problem
Home » Forums » Cyber Security Information and Advisories » Code Red – Security/Privacy advisories » Kaspersky problem
- This topic has 4 replies, 3 voices, and was last updated 15 years ago.
Viewing 3 reply threadsAuthorReplies-
WSDeadeye81
AskWoody LoungerApril 29, 2010 at 11:52 am #1221225Hi anntms,
Sometimes the newest version of a program can be problematic. I suggest uninstalling Kapersky and reinstalling the version that worked for you, and ignore prompts to update to the newest version. If there are killer bugs in the new version, they will get them fixed.
I had the same problem with Avast 5 on Windows 7. None of my protective shields were operative when I allowed the newest version of it to be installed. I removed it and installed from the executable I had earlier downloaded, and all worked well again. Eventually there was a more recent program update available, so I installed and that one worked well.
Hope this helps.
WSanntms
WSSpiritWind
AskWoody LoungerApril 29, 2010 at 8:15 pm #1221288Hi Ann :
I would think the most up-to-date info would be to look for or ask in the
appropiate Kaspersky Support Forum at http://forum.kaspersky.com ;
have you done that !? -
WSanntms
Viewing 3 reply threads -
The story of Windows Longhorn
19 minutes ago -
dmt_3904
1 hour, 48 minutes ago -
Are manuals extinct?
2 minutes ago -
10 hours, 56 minutes ago -
Network Issue
Casey H
2 hours, 59 minutes ago -
22 hours, 55 minutes ago -
23 hours, 21 minutes ago -
Steve Bondy
cyraxote
2 hours, 9 minutes ago -
JP
3 hours, 14 minutes ago -
thymej
1 day, 22 hours ago -
21 hours, 37 minutes ago -
Lance Whitney
1 hour, 15 minutes ago -
Spring cleanup — 2025
2 days, 4 hours ago -
Setting up Windows 11
23 hours, 7 minutes ago -
1 day, 23 hours ago -
Powershell version?
2 days ago -
SendTom Toys
11 hours, 16 minutes ago -
Add shortcut to taskbar?
2 days, 20 hours ago -
Help
2 days, 19 hours ago -
2 days, 2 hours ago -
We live in a simulation
3 days, 10 hours ago -
Netplwiz not working
2 days, 21 hours ago -
3 days, 23 hours ago -
Downloads folder location
4 days, 5 hours ago
