• Issues with Intel Smart Sound Technology
    Home » Forums » AskWoody support » Windows » Windows 11 » Windows 11 version 23H2 » Issues with Intel Smart Sound Technology
    Compatibility issues with Intel Smart Sound Technology drivers and Windows 11
    Status
    ResolvedExternal
    Affected platforms
    Client Versions Message ID Originating KB Resolved KB
    Windows 11, version 21H2 WI298400
    Windows 11, version 22H2 WI435243
    Windows 11, version 23H2 WI686188
    Intel and Microsoft have found incompatibility issues with certain versions of drivers for Intel Smart Sound Technology (Intel SST) on Intel 11th Gen Core processors and Windows 11. Windows 11 devices with the affected Intel SST driver might receive an error with a blue screen. The affected driver is named Intel® Smart Sound Technology (Intel® SST) Audio Controller under System Devices in Device Manager and is found with the file name ‘IntcAudioBus.sys‘. If this file is version 10.29.0.5152 or 10.30.0.5152, this issue can occur.
    Only devices with both an Intel 11th Gen Core processors and an Intel SST driver version of 10.29.0.5152 or 10.30.0.5152 are affected by this issue.
    To safeguard your upgrade experience, we have applied a compatibility hold on Windows 10 devices which have Intel SST driver versions 10.29.0.5152 or 10.30.0.5152. This will prevent those devices from being offered any version of Windows 11. If your organization is using Update Compliance, the safeguard IDs are:
    • Windows 11, version 21H2: 36899911
    • Windows 11, version 22H2: 41291788
    • Windows 11, version 23H2: 49561482
    Resolution: Devices which are encountering this issue will need to install newer versions of the Intel® SST Audio Controller drivers prior to updating to Windows 11. The issue is resolved by updating the Intel® Smart Sound Technology drivers to version 10.30.00.5714 and later, or 10.29.00.5714 and later. Please note that later versions of this driver might refer to only the last part of the version number. For the purpose of addressing this issue, 10.30.x versions are not newer than 10.29.x versions.
    For most users, updated drivers can be installed via Windows update by checking for Windows updates on your device. This is the preferred method of installing these and other drivers. If your device still encounters this safeguard hold 48 hours after updating your drivers, it’s possible drivers for this Audio Controller haven’t been developed for your specific device hardware configuration. In this case, you will need to contact your device manufacturer (OEM) for more information on the necessary drivers. Microsoft works to make the latest compatible drivers available under Windows Update whenever developers have released them.
    IT admins in organizations where devices are managed can refer to the following resources to deploy drivers using one of these tools:
    Once you have updated to a compatible version of the Intel® Smart Sound Technology drivers, you should be able to upgrade to Windows 11. Please note, if there are no other safeguards that affect your device, it can take up to 48 hours before the upgrade to Windows 11 is offered. We recommend that you do not attempt to manually upgrade using the ‘Update now’ button or the Media Creation Tool until you have performed the necessary driver updates.
    • #2660461
      the Intel® Smart Sound Technology 10.29.00.5714 driver is available from the Microsoft Update Catalog site (listed as “Intel(R) Corporation – System – 10.29.0.5714”)
    • #2684695
      Why does Windows Updates not push the new driver to my PC?   I currently have driver version 10.29.0.9947 from 10/13/2023. But on the Windows Update Catalog, it shows version 20.40.10495.4, which was released on 2/8/2024….   with many updates before that, which are newer than my current installed version.
      https://www.catalog.update.microsoft.com/Search.aspx?q=Intel+Smart+sound+for+USB+Audio
      • #2684710
        AskWoody recommends that you get your device drivers from the PC OEM manufacturer for your computer model OR from the OEM Device manufacturer to be sure that it is the correct driver for your specific device/model. MS provided drivers are not always correct.
    Reply To: Issues with Intel Smart Sound Technology
