• Intel Management Engine Interface is not compatible with Win7
    Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » Intel Management Engine Interface is not compatible with Win7
    The Win7 Upgrade advisor says that the Intel Management Engine Interface (IMEI) is not compatible with Win7. This is what I have found out so far:
      [*]Gateway support says “The Intel Management Engine Interface enables communication between the host OS and the Management Engine firmware. MEI is bi-directional, and either the host or Intel AMT firmware can initiate transactions.” When I asked what that all meant they said since the computer was no longer under warranty they couldn’t help and I should contact Intel.
      [*]The Intel site has user boards where I posted a question but have yet to get a response. It appears that most of the questions asked don’t get much of a response.
      [*]Gateway does have a BIOS update and (I think) a MB update for my machine.
      [*]There is an item in Device Manager for the IMEI.
    My questions are:
      [*]Should I just select the IMEI in Device Manager and update the driver? That seems “safer” than updating the BIOS but since it is listed under System Devices, I’m not sure I should touch it.
      [*]Would updating the BIOS update the IMEI?
      [*]Can anyone interpret the Gateway explanation of the IMEI for me? Maybe I don’t need to do anything.
    Note that I did partially ask about this in another [post=”767641″]topic [/post]but that post was more about general aspects of doing the clean install for Win7.
    TIA
    Reply To: Intel Management Engine Interface is not compatible with Win7
