Thisoccurred recently. I run IE9. When it needed it to automatically load with apage for eg from an email, IE9 came up blank. I added a tick in LAN options toautomatic and everything worked fine. But when I reboot or start up in themorning I get the same set of circumstances and have to reset the LAN settingagain by ticking “automatic”. This again lasts for my current sessionbut not on reboot. Can anyone please help. Thanks.
IE9 will not retain LAN settings
Home » Forums » AskWoody support » Windows » Windows – other » IE9 will not retain LAN settings
- This topic has 4 replies, 3 voices, and was last updated 12 years, 8 months ago.
Viewing 3 reply threadsAuthorReplies-
WSjwitalka
AskWoody LoungerJuly 13, 2012 at 7:02 pm #1340823See if the same problem occurs with a Clean Boot. See :
http://support.microsoft.com/kb/331796If the automatic setting doesn’t get reset with Clean Boot, enable things in groups to find the culprit.
Jerry
WSSelwyn
WSMedico
AskWoody LoungerJuly 27, 2012 at 2:48 pm #1342757I you have so many start up programs, you are probably also suffering from a slow down of your PC. Most of the items that tend to load themselves into start up are definitely not needed and do nothing but slow you down. If this is also a problem, you might try a small app called What’s In Startup. This little app shows what does start with Windows and allows you to disable or delete all the unnecessary stuff. Scroll to the bottom of the page for the download link.
This might also be causing an interference with IE.
WSjwitalka
AskWoody LoungerJuly 27, 2012 at 3:37 pm #1342785I would start by enabling half of your startup programs. If the problem reappears, disable half of this half. If the problem doesn’t reappear, enable half of the other half. Rinse , repeat until you identify the culprit.
As Ted said, you probably don’t need most of the startup items. You can look them up in this database which will tell you if you can safely disable them:
http://www.bleepingcomputer.com/startups/Jerry
Viewing 3 reply threads -
Apple zero days for April
57 minutes ago -
CVE program gets last-minute funding from CISA – and maybe a new home
2 hours, 50 minutes ago -
Whistleblower describes DOGE IT dept rumpus at America’s labor watchdog
3 hours ago -
Seeing BSOD’s on 24H2?
5 hours, 50 minutes ago -
TUT For Private Llama LLM, Local Installation and Isolated from the Internet.
9 hours, 16 minutes ago -
Upgrade from Windows 10 to 11
Holdsworth8
11 hours, 40 minutes ago -
Microsoft : AI-powered deception: Emerging fraud threats and countermeasures
14 hours, 30 minutes ago -
0patch
WSjcgc50
2 hours, 15 minutes ago -
Devices might encounter blue screen exception with the recent Windows updates
7 hours, 52 minutes ago -
Windows 11 Insider Preview Build 22631.5261 (23H2) released to Release Preview
17 hours, 29 minutes ago -
Problem opening image attachments
RobertG
19 hours, 4 minutes ago -
advice for setting up a new windows computer
routtco1001
1 day, 9 hours ago -
It’s Identity Theft Day!
14 hours, 6 minutes ago -
Android 15 require minimum 32GB of storage
Mac Mini 2018, iPhone 6s 2015 Are Now Vintage
Hertz says hackers stole customer credit card and driver’s license data
Firefox became sluggish
Rick Corbett
Windows 10 Build 19045.5794 (22H2) to Release Preview Channel
Windows 11 Insider Preview Build 22635.5235 (23H2) released to BETA
A Funny Thing Happened on the Way to the Forum
16 hours, 56 minutes ago -
Download speeds only 0.3Mbps after 24H2 upgrade on WiFi and Ethernet
John
1 hour, 37 minutes ago -
T-Mobile 5G Wireless Internet
WSmmi16
17 hours, 37 minutes ago -
Clock missing above calendar in Windows 10
WSCape Sand
18 hours, 49 minutes ago -
Formula to Calculate Q1, Q2, Q3, or Q4 of the Year?
WSJon5
2 days, 10 hours ago -
The time has come for AI-generated art
Catherine Barrett
Hackers are using two-factor authentication to infect you
2 days ago -
23 and you
Max Stul Oppenheimer
2 days, 7 hours ago -
April’s deluge of patches
11 hours, 22 minutes ago -
Windows 11 Windows Updater question
1 hour, 18 minutes ago -
Key, Key, my kingdom for a Key!
3 days, 16 hours ago
