I have a 3-column worksheet where I need to perform a look based on the first to columns to return the result of the third column.
The first Column contains the account number and they repeat. The second column contains the business unit and they also repeat. But each business unit will only have one instance of each account number, so together, they create a unique row number.
A regular VLOOKUP will not work since there are two criteria and an INDEX MATCH formula does not seem to work since that combo is looking for vertical and horizontal arguments.
I am attaching a spreadsheet that demonstrates how my lists are set up.
If any one can provide a solution using formulas, it will be greatly appreciated.
PS: I know that Access can do this very easily with a CrossTab query, but Access is not an option at this point.
Thanks,
