For a year – after one of the updates of Samsung KIES – I could not connect my Samsung GT9001 to my PC. MTP-USB driver failed to install.
On the forums of Microsoft , the MS people say you have to contact Samsung etc. and Samsung (but e.g. also Nokia) says : contact MS. None of the forums or help-desks provided a solution.
Then on the Dutch MS forum, I found a tread about a Canon-camera, that uses MTP-USB.
there was a work-around:
1 remove the problematic failed app, if it is in “hardware”
2 remove all USB controllers
3 Des-activate Windows Media Player
4 reboot (the usb controllers are reinstalled then)
5 Reactivate Windows Media Player.
It seems that WMP installs a MTP-USB driver in this case.
and yes it worked !!:D
(we will see what the next Samsung KIES update will do :^_^:
I found a solution for MTP-USB driver does not install
- This topic has 1 reply, 2 voices, and was last updated 10 years, 5 months ago.
AuthorViewing 0 reply threadsAuthorViewing 0 reply threads
