• HP wireless keyboard problem
    I have a wireless keyboard / mouse that suddenly started acting strangely.
    I changed batteries and that seemed to help for a short period.
    While typing it seems there is something in background grabbing all of the machines cycles and I only get a portion of the letters typed. I checked task mgr and can’t see anything taking over system.
    When trying to make multple selections using “Ctrl” it loses focus and I have to resort to singles selections at a time.
    Do these keyboards some times just wear out – is it time for a new keyboard?
    Tom
    • #1163578
      Tom
      ANYTHING can wear over time, even us!
      How old is the unit? How much use does it get?
      Have you checked for updated drivers from the manufacturer?
      I don’t use wireless hardware but wired units are dirt cheap these days and even wireless is relatively inexpensive, so how much time you spend troubleshooting this problem, probably isn’t worth it.
    • #1163640
      In addition to what Bob said, I always suggest to people that you check your antivirus and/or malware software to see if one of them might be hogging a resource and thus inhibiting the mouse/keyboard.
      You can’t always tell from Task Manager, so you may have to temporarily disable something to see if the problem abates.
    Reply To: HP wireless keyboard problem
