• How to speed up a macro (excel 97)
    Hello again guys,
    Don’t know if this possible..I run 1 of my macro
    and it take nearly 3 minutes to finish..How can
    I speed it and make it run a little(more faster is better)..
    I know “application.screenupdating” will not works in this
    method coz i have try it..it will only hide what’s going
    on but not increasing the code peed..any ideas..
    my range that i run using the macro is from b9:ab78
    its not big though..but its took me nearly 3 minutes to
    run the macro..any help will be appreaciated
    ps: if you know the method..please guide me where should i put
    it..i.e maybe after the variable , or before the end sub or etc..thanks again
    • #536212
      It is impossible to say without looking ay the code. Could you let us see what the code is doing ?
      In the meantime you could try
      Application.Calculation = xlCalculationManual
      before the code runs and reset to
      Application.Calculation = xlCalculationAutomatic
      when finished and see if that helps.
      Andrew C
    • #536218
      Application.LudicriousSpeed = True grin
      I agree with Andrew. We’d need to see the code.
      lightbulbOne thing I can think of is to use the With statment. The less periods you drill down, the better performance you get. At least I think I had heard that somewhere.
      • #536224
        you did and I think you’re right. this might be worth a look.
        Brooke
    • #536310
      My code give the wrong answer. It should calculate 1 but it calculates 2. Can you tell me why without seeing the code? smile
      That is just as easy as what you are asking without showing your code.
    • #538285
      Are you doing any page setups in that code? That is notoriously slow. It is better to use the ancient XL4 macro command for that:
      application.ExecuteExcel4Macro(“PAGE.SETUP(head, foot, left, right, top, bot, hdng, grid, h_cntr, v_cntr, orient, paper_size, scale, pg_num, pg_order, bw_cells, quality, head_margin, foot_margin, notes, draft)”)
      This command (e.g.) shows the gridlines:
      Application.ExecuteExcel4Macro (“PAGE.SETUP(, , , , , , , true, , , , , , , , , , , , , )”)
    Reply To: How to speed up a macro (excel 97)
