• How to resolve synchronization problems in OneDrive
    Home » Forums » Newsletter and Homepage topics » How to resolve synchronization problems in OneDrive
    ISSUE 20.24 • 2023-06-12 ONEDRIVE By Lance Whitney Sometimes OneDrive fails to properly sync your files. Here’s how to deal with these annoying issues
    [See the full post at: How to resolve synchronization problems in OneDrive]
    • #2565499
      Nice article, but it doesn’t cover the issue I have with OneDrive – how to specify a folder NOT to sync to OneDrive.  Used to be able to do that in settings, but that option has disappeared on my system.  I even added a data drive to store game files and backups that I don’t want sync’d, but OneDrive has found it and is backing it up anyway.
      • #2565641
        Something like this From MS —
        Open OneDrive settings (select the OneDrive cloud icon in your notification area, and then select the OneDrive Help and Settings icon then Settings.)
        Go to the Account tab.
        Select Choose folders.
        That said I have an inherent distrust of syncing by anything and usually find it confusing. In addition One Drive seems too aggressive in it’s initial choice of folders, so you definitely want to select folders which folders are syncing or simply turn it off. I prefer to manually post files to Dropbox. In researching syncing files, I found that there are inherent issues that make it problematic.
    • #2565534
      The solution is to simply use Google Drive instead of OneDrive. Considerably less buggy.
      Only reason to use OneDrive is because it comes company-provided 365 licenses.
    Reply To: How to resolve synchronization problems in OneDrive
