• How to manage floppy drive programs on PC without floppy drive?
    Home » Forums » AskWoody support » Windows » Windows Vista, XP and earlier » Questions: Vista, XP back to 3.1 » How to manage floppy drive programs on PC without floppy drive?
    Hi all,
    This topic comes and bites me in the bum periodically. What I’d like is to have some way of transferring the data currently on various bootable floppies to a USB stick so I can still boot these programs in an XP SP3 machine without a floppy drive.
    I’ve tried to inform myself on the web. Some give this advice, some give that advice – it’s difficult to know how to find my way through this forest.
    I don’t want to burn a disk image of each floppy I have to a CD/DVD, so what possibilities are there of using a USB stick to boot the various programs and what would I have to reconfigure to get it to work?
    Thank you very much for your help!
    Viewing 8 reply threads
    • #1389733
      Sounds like all you would need to do is install the program on a bootable USB drive, and set your computer, in BIOS, to recognise bootable USB sticks.
      Most BIOS’s also have a function button you can press that allows you to select a boot device.
    • #1389832
      I haven’t been able to figure out yet how you could transfer bootable programs on floppy disks onto a bootable USB flash drive without an imaging program/procedure
      Since you say you don’t want to burn a disk image of each floppy to a CD that tells me you still have the PC on which you can use those floppy disks so would you consider the following ideas?
      — Remove the floppy drive from that computer and install it into the XP SP3 computer or connect it externally
      — Or buy an external floppy drive to connect to the XP SP3 computer
      — That way you can at least use those floppy disks with their programs & data as you have been providing they are compatible with XP
      Then see what it would take to transfer the programs & data to a bootable USB flash drive from there
      — However, without an imaging program/procedure I do not see how that can be accomplished
      — What are the programs and how many are there?
      — Maybe there are modern versions of those programs you can install on the XP SP3 PC or even onto a flash drive
      — It might cost to get the modern version but that’s the trade-off you would need to consider
    • #1389837
      Hi all,
      I’ve been doing what you ask, for several years now. It IS a multi-step process but it’s not really difficult.
      Of course you need a PC with a floppy drive to read the original floppy disks.
      Next you need a little utility from HP that allows you to format a Flash Drive, utilizing the 3 boot files from the floppy.
      First, download and install the Utility.
      https://www.box.com/s/ug2xqy1m7xp27avqmeg2
      Then once you format the Flash drive, using the boot files from the Floppy, copy the rest of the files from the Floppy Disk to the Flash Drive.
      The nice thing is, you can add and remove programs and files from the Flash Drive just like you would the floppy disk, only most Flash Drives are much larger. I have several Flash Drives set up with programs that I used to use from a Floppy Disk.
      If you need more details, drop me a PM.
      Good Luck!
      The Doctor 😎
      PS: If you have a CD burning program like “Nero”, you can create a bootable CD from a Bootable Flash Drive.
      I’ve done that too, because many PC’s can’t be booted up from a Flash Drive.
      • #1389839
        Hey Doc,
        I have a question…When installing XP , the F6 option wants input from a floppy …To install Drivers etc. … Could this “Tweak” ( flash drive ) be used to simulate a “Floppy” ?:cheers: Regards Fred
        • #1389950
          No, it won’t. The utility Doc linked to is merely one of several ways to make a flash drive bootable, but that’s it’s only focus. It doesn’t make a flash drive appear to be a floppy.
          The F6 option in XP-Setup looks only for a floppy in drive A: (and possibly drive B:, though I haven’t tested that). A flash drive, bootable or not, typically shows up as a hard drive–i.e., drive C: or higher. F6 doesn’t look there.
          Also note the F6 option doesn’t care whether the medium is bootable. It doesn’t need to be bootable, it just needs to hold the SATA driver files so they can be retrieved when F6 goes looking for them. You can copy the driver files to a flash drive but unless that flash drive shows up as A: or B: then F6 won’t find them.
          • #1389953
            No, it won’t.
            dg,
            Hello.. Thanks for the clarification … If you were to place “SATA Drivers” on a flash drive and label it “A:” ….. ( also format the flash drive FAT32) would that work? :cheers: Regards Fred
            • #1389957
              dg,
              I’ve tried that on a couple of PC’s, and it wouldn’t work. Seems that the XP installer queries the floppy controller directly. The only luck I’ve had with SATA drivers and XP was using nLite to roll them into an installation disk. That worked just fine.
              Of course, with a floppy drive, F6 works just fine, also.
    • #1390000
      I would save the boot floppies as ISO images, as a backup, then you can create bootable USB devices or CDs as required.
      Tools Required (free, of course)
      CDBurnerXP – create floppy images, save ISOs, burn bootable CDs.
      Rufus – create bootable USB devices from ISO images, or direct.
      Create ISO
      1. Run CDBurnerXP and select Data disc.
      2. Select Disc > Boot options.
      3. Tick Make Disk Bootable.
      4. Click Create floppy image > Create image.
      5. When the image is ready select File > Save compilation as ISO file.
      6. Backup your newly created ISOs.
      Create USB
      1. Run Rufus.
      2. Select the ISO Image drop down and choose the ISO you require.
      3. Click Start to create the USB.
      • #1390888
        Thanks Paul. It may be silly but burning a CD for each of around 12 to 15 floppies seems a bit wasteful. Is there no other way of doing this?
        • #1391122
          You save the ISO file on your PC and if you ever need a boot floppy you burn the ISO to a CD and boot from that.
    • #1390949
      Going all the way back, to the premise of this thread,,,, for a long time, when new computers started coming out without floppy drives, I carried a New USB Floppy Disk Drive with me on every service call.
      I sold a pot full of those little drives to people who had just bought a new PC, that came with NO floppy drive installed.
      It seemed like everyone had some old floppies with family pictures or some data that they still wanted to be able to access.
      Flash Drives are a lot like floppy disks, but hold hundreds of times more data, so transferring floppies to flash drives is a good way to preserve old data. Floppies DO Forget, after a period of time and some brands forget even faster than others.
      I have a program, that makes a self restoring image file from a floppy disk. Back in the day, I’ve emailed those images to people all over the world. All they had to do was run the image (an .exe) file and it would rebuild the original floppy to a new disk.
      That was Great, for sharing files over a long distance.
      My main PC, my backup PC and my backup to my backup all have Floppy Disk Drives in them. I use floppies often.
      Cheers Mates!
      The Doctor 😎
      • #1391211
        Cheers Mates!
        The Doctor 😎
        I agree with Dr. Who about the USB floppy drive. You can get one really cheap at Tiger Direct:
        http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1489134&CatId=631
        However, as floppy disks will eventually go bad, it would be good to convert the data on these disks to a modern format, as others have described.
        If you get a USB floppy drive, you will be prepared for all situations, such as when you need to access the data immediately, and it would be inconvenient to have to convert the data to a modern format (and you haven’t yet converted it on a particular floppy disk).
        Set your computer to boot first from the USB floppy drive, so that if you ever need to do so, you will be ready. If you don’t need to do so, no harm done; if a bootable floppy is not present, it will ignore it and boot from the other eligible media.
    • #1391007
      I like your sig Dr.Who – Ghost Is Great!
    • #1391123
      Dr.Who: Thanks so much for your superb help with my OP. I’ve been having fun using WinImage to extract data from my floppy library, compressing them and converting them to self-extract.
      One question: with all the floppies I’ve copied for eventual transfer to a USB stick, there are a lot of what look like duplicate files, i.e. autoexec.bat, command.com etc. I imagine some of that data relates only to the floppy from which it came. Would I not be better to create a folder on the USB stick for each floppy and then type in the path to folder plus exe at boot time, rather than keep all the data from all the floppies mixed up in the root of the USB?
      How does all that hang together?
    • #1391125
      You can’t tell a floppy to boot from different directories, but you can customize the boot files config.sys and autoexec.bat. Personally I’d stick to one image per floppy, it’s much easier and always works.
    • #1391215
      USB drives were never my problem. I’ve been using them for years. My problem was:
      (1) How to make the USB stick bootable
      (2) How to get floppy data onto the USB stick so it was usable
      (3) How to order the data from a number of floppies on the USB stick so it was accessible.
      It seems from what you folks have said here, that I can’t copy the data from, say, 6 different floppies onto a USB stick and then access the individual floppy data without confusing both the PC and me 🙂
      But hey, thank you all. I’m much further ahead than when I started.
    Reply To: How to manage floppy drive programs on PC without floppy drive?
