My truck’s A/C is stuck on hot – the temperature control will set it on cold for a minute, then it’s back to hot.
Turns out there’s a small door in the A/C system that directs hot or cold air to the A/C vents, and it keeps getting stuck on the hot side.
I found out that there is a motor connected to this door that is controlled by the temperature knob on the A/C control panel — it is called the “actuator”.
The actuator was bad, so I bought another (US$40). But no matter what I did, I couldn’t get the new actuator installed. I figured it was out of alignment with the door, so I put a long screwdriver bit into the hole on the A/C box, and manually turned the door all the way to hot or cold (I wasn’t sure which, but I knew it was all the way in one direction or the other). I then ran the A/C for a few minutes to see if it would produce hot or cold air at the vents (it was hot). I then plugged in the new actuator and turned the temperature control all the way to the hottest setting, so that the actuator would be aligned with the door. However, even after doing all of that, I still couldn’t get the actuator installed.
Then it hit me: Why not just leave the screw driver bit in the hole, then when I want to adjust the temperature, I can reach behind the glove box and manually turn it!
Another thing hit me: Why in the world didn’t Ford just put a cable from the A/C door to the temperature control? Why put a motor which will eventually wear out, rather than a cable which will never wear out?
