• Help with SUMIF formula
    Hi,
    I have a SUMIF function that I need help with. I have multiple conditions it needs to look at to pull the sum. I think I should be using SUMIF but I am not 100% sure.
    See attached sample for what I am trying to accomplish.
    Thank you!
    • #1258035
      Hello Corden
      Have you considered using a Pivot Table/Chart as shown in the attached sample?
      Regards
      Don
    • #1258144
      Hi Corden
      Here is a second example using VBA,
      HTH
      • #1258282
        Hi Corden
        HTH
        VB code worked great as well. Thank you!
    • #1258148
      Thank you! That worked for me. Appreciate the help.
    Reply To: Help with SUMIF formula
