• Help With SQL Syntax? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Help With SQL Syntax? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
    • This topic has 1 reply, 1 voice, and was last updated 17 years ago.
    The following works OK
    strSQL = "SELECT Count(curVBen) AS NumberOfRecords, " & _
                    "Sum(curVBen) AS TotalBenefit, " & _
                    "Sum(curVFee) AS TotalFee, " & _
                    "Sum(curAmtAllowed) AS TotalAllowed, " & _
                    "Sum(curAmtApplToDed) AS ApplToDed, " & _
                    "Sum(curAmtNotCovered) AS NotCovered " _
                    & "FROM " & strTable & " " _
                    & "WHERE (((" & strTable & ".dteVDATE) " _
                    & "BETWEEN #" & gloGetValue("StartDate") & "# " _
                    & "AND #" & gloGetValue("EndDate") & "#) " _
                    & "AND ((" & strTable & "." & strCode & ") " _
                    & "BETWEEN '" & gloGetValue("StartProcedureGroupCode") & "' " _
                    & "AND '" & gloGetValue("EndProcedureGroupCode") & "') " _
                    & "AND ((" & strTable & ".idsKeyOfPersonal)=" _
                    & PersonalID & "))"
    I’m trying to streamline the following code in a form and I’m getting and I am getting “3265 Item not found in collection” error
                        "Sum(curAmtAllowed) AS TotalAllowed " _
                        & "WHERE (((" & strTable & "." & strCode & ") " _
                        & "= '" & gloGetValue("StartProcedureGroupCode") & "' " _
                        & PersonalID & ")))"
    Debug.Print strSQL
    However, I can run the the contents of strSQL in query grid OK
    FROM qrytblSumServetblVouch2_NoVoids
    WHERE (((qrytblSumServetblVouch2_NoVoids.strProcedureGroup) = 'O'
    AND ((qrytblSumServetblVouch2_NoVoids.idsKeyOfPersonal)=1632)))
    Where is my problem?
    Thanks, John
    • #1107664
      I retyped it and it works
    Reply To: Help With SQL Syntax? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
