• Help With fld.Properties. Syntax? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Help With fld.Properties. Syntax? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
    Need the correct syntax to set the Format property to “>” for BE, table and field
    strBE=F:AppsAccess2kClerkTlaClerk.md
    strTbl=tbl_DL_Breed
    strFld=strBreedCode
    Thanks, John
    Public Sub SetFormat(strBE As String, strTbl As String, strFld As String)
        Dim dbs As DAO.Database
        Dim tdf As DAO.TableDef
        Dim fld As DAO.Field
        On Error GoTo ErrHandler
        Set dbs = DBEngine.OpenDatabase(strBE)
        Set tdf = dbs.TableDefs(strTbl)
        Set fld = tdf.Fields(strFld)
        ??? fld.Properties.Append "Format", ">"
    ExitHandler:
        On Error Resume Next
        Set fld = Nothing
        Set tdf = Nothing
        dbs.Close
        Set dbs = Nothing
        Exit Sub
    ErrHandler:
        MsgBox Err & ": " & Err.Description, vbExclamation
        Resume ExitHandler
    • #1087896
      You must create the property if it doesn’t exist yet (fields start out without a Format property). You can do this in the error handler if error 3270 occurs (property not found):
      fld.Properties("Format") = ">"
      ExitHandler:
      Set fld = Nothing
      Set tdf = Nothing
      dbs.Close
      Set dbs = Nothing
      Exit Sub
      ErrHandler:
      If Err = 3270 Then
      fld.Properties.Append fld.CreateProperty("Format", dbText, ">")
      Resume Next
      Else
      Resume ExitHandler
    Reply To: Help With fld.Properties. Syntax? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
