• Help with code (A2K)
    I found this code on the web to search your hard drive for files. The code returns the path and file name.
    I’m trying to populate a table with the results for a design feature later. I added a function “Populate” that
    I thought would fill in the table(tblLocations). When the code gets to the OpenRecordset line it jumps back to
    a line in the “Function FindSubFolders(folderspec)” function. I can’t figure out why.
    Call FileSearch to run and replace the “Training.mdb” with a file name on your hard drive.
    The results print in the debug window.
    Here is the code:
    Function FileSearch()
    Dim fso
    Set fso = CreateObject("Scripting.FileSystemObject")
        'On Error Resume Next
        Dim d, dc, s
            Set dc = fso.Drives
            For Each d In dc
            If d.DriveType = 2 Then 'Or d.DriveType = 3 Then '2= Local 3 = Network
                Call FindSubFolders(d.Path & "") 'Find Folders in Drive
            Next
        End Function
        Dim fso
        Dim f, f1, sf
        Set f = fso.GetFolder(folderspec)
        Set sf = f.SubFolders 'Find sub folders
        For Each f1 In sf
            DoEvents
            Call FindFiles(f1.Path) 'find files in dir
            Call FindSubFolders(f1.Path)  'Recall to get the sub folders 'Jumps back to here
        Next
    End Function
    Function FindFiles(folderspec)
    Dim fso, fc, f, s
    Dim file1 As String
    Dim f1
    Dim strField1 As String
    Dim strField2 As Variant
        file1 = "training.mdb" ' file you are looking to find on the hard drive.
        Set fc = f.Files
        For Each f1 In fc
            s = fso.GetFileName(f1.Path)
            DoEvents
            If s = file1 Then
                Debug.Print f1.Path
         strField1 = file1
         strField2 = f1.Path
        Call Populate(strField1, strField2)
        Next
    End Function
    Function Populate(strField1 As String, strField2)
    Dim db As Database
    Dim rs As Recordset
    Dim strSql As String
    Set db = CurrentDb
    strSql = "Select tblLocations.* FROM tblLocations"
    Set rs = db.OpenRecordset(strSql, dbOpenDynaset)
    rs.AddNew
    rs!Database = strField1
    rs!Path = strField2
    rs.Update
    rs.Close
    Set rs = Nothing
    End Function
    Reply To: Help with code (A2K)
