• Help with Code
    Hi All
    I need some help with this code. I’d like to be able to multi select various cells in row 7 and get the code to select the respective columns. Also it appears that code only selects the column to the last cell with content, I’d like it to select the column/s to say row 500
    Sub SelectColumn()
    ‘Updateby20140510
    Dim xColIndex As Integer
    Dim xRowIndex As Integer
    xIndex = Application.ActiveCell.Column
    xRowIndex = Application.ActiveSheet.Cells(Rows.Count, xIndex).End(xlUp).Row
    Range(Cells(7, xIndex), Cells(xRowIndex, xIndex)).Select
    ‘Selection.Delete Shift:=xlToLeft
    I hope that makes sense – any help/suggestions would be much appreciated
    Regards
    Viewing 15 reply threads
    • #1532374
      Your code starts in the active column. How do you determine what the “respective columns” are?
      • #1532382
        Hi Paul
        I was thinking of the shift click on various cells along row 7 and these would then determine what the “respective columns” are.
        Regards
        • #1532384
          Hi verad
          Do you mean a continuous range as in Shift+Click or discontinuous with control +click?
          If a continuous selection then what about something like this as something different.
          You pas in the starting cell, columnOffset and rows required.
          If it looks likely then some tidying up is required.
          Code:
          Sub main()
              defineSelection "A7", 5, 100
          Sub defineSelection(rStart, colOffset, rowCount)
              Range(rStart).Select
              Range(ActiveCell, ActiveCell.Offset(0, colOffset)).Select
              Range(Selection, Selection.Offset(rowCount, 0)).Select
          Cheers
          Geof
          • #1532630
            Thanks Geof
            Sorry I meant discontinuous with control +click.
            Looks like your code is pretty close – just needs to take into account the discontinuous with control +click cell selection and then selecting (and deleting) the respective column/s.
            Cheers
    • #1532386
      Something like this?
      Code:
      Sub SelectColumn()
          Dim rArea                 As Range
          Dim rSel                  As Range
          For Each rArea In Selection.Areas
              If rSel Is Nothing Then
                  Set rSel = rArea.EntireColumn.Resize(500)
              Else
                  Set rSel = Union(rSel, rArea.EntireColumn.Resize(500))
          Next rArea
          rSel.Select
          'rsel.Delete Shift:=xlToLeft
      • #1532632
        Thanks Rory – that looks very close also.
        I’ve attached a smaple of the spread sheet to give you (and any others) a better idea of what I’m tring to get the code to achieve.
        I’ve highlited Cells H2, J2 & L2 as I would using the discontinuous with control +click cell selection.
        I’d like the code to delete the entire column including the cell selections.
        Hope this helps
    • #1532637
      Verada,
      A slight twist. This code will append the selection of the columns as you select any cell in row 7. Click any cell in any other row to clear the selection.
      Place in the worksheet module:
      Code:
      Private strng As String
      Private Sub Worksheet_SelectionChange(ByVal Target As Range)
      If Target.Row = 7 Then
          col = Target.Column
          If strng = “” Then
              strng = Range(Cells(1, col), Cells(500, col)).Address
          Else:
              strng = strng & “,” & Range(Cells(1, col), Cells(500, col)).Address
          Application.EnableEvents = False
              Range(strng).Select
          Application.EnableEvents = True
      Else:
          strng = “”
      HTH,
      Maud
      • #1532650
        Hi Maud,
        Sorry I don’t really get this one:confused:
        What do you mean append the selection?
        Thanks again for your help
        Regards
    • #1532641
      I’ve highlited Cells H2, J2 & L2 as I would using the discontinuous with control +click cell selection. I’d like the code to delete the entire column including the cell selections.
      Verada,
      If you want to delete the columns as you select instead of having to manually run a macro, place this code in the worksheet module. If you select any cell in row 2, the column of the section will be deleted. Continue to delete as many columns as needed
      Code:
          If Target.Count > 1 Then Exit Sub
          If Target.Row = 2 Then
              Target.EntireColumn.Delete
      Maud
    • #1532646
      Thanks Maud
      That look really good, only issue is that I need to delete the column including row 2 but keep the row 1 as it was.
      I guess I wasn’t clear when I indicated “Id like the code to delete the entire column including the cell” sorry about that.
      Also, can is there anyway that the normal “Undo” option is available in case a column is deleted in error?
      Your assistance is very much appreciated
      Regards
    • #1532681
      You’ll lose the undo stack whenever you run code that alters the sheet.
      What exactly do you mean by deleting the column? Do you mean just clearing the contents or actually deleting the cells? If the latter, which way should cells shift – up or left – to fill the space?
      • #1533035
        Hi Rory, Thanks for the reply
        May need to include a message in the code like “are you sure…?”
        Sorry I want very clear in the deleting column – what I’m after is the column from the cell you select, say A7, all cell (including A7) down to say 500 are selected and the and a shift left happens to fill the space.
        Hope that helps
        Regards
    • #1533047
      Verada,
      I have overcome the “Undo” issue by having the code store the column prior to deleting the data making it retrievable. But I am confused exactly what you want to delete. Can you clarify?
      Maud
    • #1533070
      Hi Maud – Thanks again for your help.
      Sorry I’ll try to clarify.
      Lets say I need to remove all the cells from A7 to A500 (but leave A1 – A6 as they are). I click in A7 that highlights all cells to A500 (but could be any column/s) and the shift left would occur. This is the code from the macro I recorded – Selection.Delete Shift:=xlToLeft
      I hope that helps
      Much appreciated.
      Regards
    • #1533193
      Thanks Verada for clarifying. Below is the code that will do the following. If you click on any cell in row 7, the cells in that column (from rows 7-500) will be deleted and a shift left would occur. If a mistake was made, running the “reset” routine will place the deleted cells back by shifting to the right and insert.
      In the attached modified version of your worksheet, I have set the key combination of Ctrl-z to undo the delete process.
      HTH,
      Maud
      Code:
              Dim rng As Range, cell As Range
              col = Target.Column
              nme = ActiveSheet.Name
              num = ActiveSheet.Index
              Set rng = Range(Cells(7, col), Cells(500, col))
              rng.Copy
              With Worksheets(“Hidden”)
                  .Visible = True
                  .Select
                  .Range(“A1”).Select
                  ActiveSheet.Paste
                  .Range(“B1”) = nme
                  .Range(“C1”) = rng.Address
                  .Visible = xlVeryHidden
                  Worksheets(Index).Select
              End With
              rng.Delete Shift:=xlToLeft
      Public Sub reset()
      On Error GoTo errorhandler
              .Visible = True
              nme = .Range(“B1”)
              num = .Range(“C1”)
              .Select
              .Range(“A1:A493”).Copy
              Worksheets(nme).Select
              Range(num).Select
              With Selection
                  .Insert Shift:=xlToRight
                  .Item(1).Select
              End With
          End With
      Exit Sub
      errorhandler:
    • #1533396
      Hi Maud – thanks for the Code. Sorry about the delay in getting back to you on this but I’ve been out of town for the last few days.
      I’ve plugged it into the actual spreadsheet and ran the code and received an Run-time error ‘9’: subscript out of range on “With Worksheets(“Hidden”)”
      Any idea what needs to be done to fix this error.
      Regards
    • #1533407
      Verada,
      Create a sheet called Hidden. That is where the deleted cells and their format get written to so that they can be recalled with the reset function (undo)
    • #1533432
      Thanks Maud – included a sheet called Hidden and Worksheet_SelectionChange works just fine ( I should have worked that one out – my bad!)
      However I get an error “beep” when I hit the Ctrl-z to undo the delete process – any idea what might be causing this or am I doing something wrong
      Regards
    • #1533434
      Try just running the reset routine through the macro button on the Developer tab. If all is OK then Perhaps that key combination is assigned to another task. Try assigning something like Ctrl-q to the reset macro
      Developer Tab > Macros button > Select reset macro in large list box> Options > press the q key> OK > “X” to close.
      You might also try assigning the reset macro to a form button.
      Maud
      • #1533440
        Hi Maud – I worked out what the problem is (but not the solution unfortunately)
        Sometimes the spreadsheet may have more than one tab (like “Worksheet”, “Worksheet 1”, “Worksheet 2”, etc)
        So the reset routine works fine in “Worksheet” but not the others.
        Is it a relevantly some task to be able to recover the data back to the Worksheet it came from or would it be a better option to include a message “Are you sure you want to delete this record” ?
        Thanks for your assistance once again.
        Regards
    • #1533435
      Ok great – thanks for your help
      Much appreciated
    • #1534361
      Verada,
      If you want the code to be usable for any sheet then apply the following changes:
      Remove the existing code from the worksheet module.
      In the worksheet module for each sheet you wanted to apply the behavior to, enter this code:
      Code:
          DelCells ActiveSheet.Index
      In a standard module, enter the following code:
      Code:
      Public Sub DelCells(num)
          With Worksheets(num)
              If Selection.Count > 1 Then Exit Sub
              If Selection.Row = 7 Then
                  col = Selection.Column
                  Set rng = .Range(.Cells(7, col), .Cells(500, col))
                  rng.Copy
                      .Visible = True
                      .Select
                      .Range(“A1”).Select
                      ActiveSheet.Paste
                      .Range(“B1”) = nme
                      Worksheets(num).Select
                  End With
          End With
      Public Sub reset()
              .Visible = True
              nme = .Range(“B1”)
              num = .Range(“C1”)
              .Select
              Range(num).Select
              With Selection
                  .Item(1).Select
              End With
          End With
      Exit Sub
      errorhandler:
    • #1534436
      Thanks Maud,
      Thanks looks just right.
      Thanks you again for all you help, very much appreciated
      Regards
    Reply To: Help with Code
