How do I make the help tips appear when I position the cursor over a textbox , or any other control?
Code? or can I do it directly in the properties manager of the textbox? How?
Thank you
Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » help tips when mouse over text box (2002)
I am by know means an expert, I do NOT think there is a DIRECT way to do this.
The only way I know to do this (using the adage, if you don’t know an easy way, do it the difficult way) is to add a label on where you want the “tooltip” to be. Add text and format (size, color, etc) as desired
Then in the “mousemove” event of the texbox add this code
Private Sub TextBox1_MouseMove(ByVal Button As Integer, ByVal Shift As Integer, _ ByVal X As Single, ByVal Y As Single) Dim sSens As Single Dim sXLo As Single Dim sXHigh As Single Dim sYLo As Single Dim sYHigh As Single Dim oTip As Object Dim obj As Object sSens = 0.1 Set oTip = Label1 Set obj = TextBox1 sXLo = obj.Width * sSens sYLo = obj.Height * sSens sXHigh = obj.Width * (1 - sSens) sYHigh = obj.Height * (1 - sSens) If X > sXLo And X sYLo And Y < sYHigh Then oTip.Visible = True Else oTip.Visible = False End If End Sub
It will unhide when the mouse is in the “center area” of the textbox and hide it when it gets near the border. The width of the change is determined by the “sensitivity” (sSens) which is set at 10% of the width/height. if too small you might not rehide the tip if you move over the textbox really fast.
Change the objects as appropriate.
Steve
I am just a chemist, who plays with excel. There is a lot I use (and am fairly knowledgeable in), there are items I know about, and have to think about them, and there are things I have never seen but I have heard about, and there are things I have never seen and am not sure they exist.
There are the occasional example of these “can they be done” items, that I knew of no direct way, and have done a workaround and then someone gives an easier way. Look at post 295925 and my algebraic solution to an existing “built-in” function. (at least my algebra was correct).
Maybe a “real excel expert” will tell us how to do it easily!
Steve
I will try your advice.
In the mean time, I wrote a short piece of code that did the trick:
Private Sub x_spacing_GotFocus()
Dim message As String
message = “If transpose direction is 1:” & vbCrLf
message = message & vbTab & “X spacing will set the control point spacing WITHIN the new ribs” & vbCrLf
message = message & vbTab & “Y spacing will define the distance among ribs” & vbCrLf
MsgBox message
Its primitive, doesnt have the font formatting, and it is very annoying if you have to correct the values you typed in the textbox very often (the msgbox will pop up every time you select the textbox)… but it did the job too!
I have a high school degree in chemistry… does that help?
MsgBox message
Steve
Steve
Notifications
