I regularly make system recovery disks and today had a use for them. System boots with rescue disk in CD drive, then Windows files load from disk, then MS progress bar chugs along, then first screen with Windows background appears behind “System Recovery Options” box that asks me to “Select a keyboard input method.” It suggests “US” as appropriate, but the two buttons — “Next” (highlighted) and “Cancel” — are not responsive to any key, and no mouse cursor with which to click on either button is present. I’m using a Microsoft keyboard and mouse, which the BIOS sees before loading Windows Recovery! This occurs with all the recovery disks I’ve accumulated. Something else I might do? Is there a soft keyboard to call up and use?
Windows 7 Pro SP1 64-bit, up to date.
