• Help!! Project locked, but I didn’t lock it? (Word 2002 (Office XP))
    Home » Forums » AskWoody support » Productivity software by function » Visual Basic for Applications » Help!! Project locked, but I didn’t lock it? (Word 2002 (Office XP))
    Hi,
    I don’t know why, but I can no longer access my Normal.dot file. When I go into VBA, it tells me my project is unviewable because it is locked.
    But I haven’t locked it!!
    What can I do? Where can I unlock it?
    Chris
    • #558103
      Can you File>Open the Normal.dot file in question?
      • #558107
        Yes, but I still get the same message when I try to access it in the VBA. Do you have any ideas?
        Thanks smile
        • #558133
          Open it first. Then switch to the IDE and right click on Normal in the “Project Explorer”. If the project (Normal) is locked you’ll be prompted for a password. You obvioulsy need to know the password to open that project for editing.
          Are you prompted for a password when you try the above?
    • #558284
      Hmmm… I’ve seen it wherey you need to open the template by File Open, and pointing at the .dot template. Otherwise the modules are locked out. I don’t know if this works for the normal.dot.
      shrug shrug
    • #558311
      Did you import the Normal.dot from Word 6 or 7?
      If so, you may have at least one executable-only macro, which causes the entire project to be “locked”.
      In this case, the only solution is to re-import the WordBasic, but remove any executable-only macros or replace them with the source version.
    Reply To: Help!! Project locked, but I didn’t lock it? (Word 2002 (Office XP))
