• Help! create a flash turorial
    I’m a novice of flash, but I want to make a flash demo for online tutorial.Could any one recommend me some software for that?
    thanks in advance.
    • #1816354
      If you want to record yourself manipulating an application’s UI, there are numerous free and non-free products you can try.
      If you search here for Wink, you can find a link to that one. There is a open source one I saw mentioned on the comments for one of the recent Giveaway Of The Day items, but I didn’t try it myself.
      One that is not free but worked well when I tried it a few years ago is ViewletBuilder from Qarbon.
    • #1816355
      Have a look at Wink.
      Alan
    • #1816356
      Never used either myself, but Demo Builder and Flash Demo Builder look like they might do what you want.
    • #1816357
      You also may want to look at Adobe Capitivate 2 found as a Demo on the Adobe website. You will need to create an account which is free to get any trial doownload. It will be fully functional for 30 days. You can view small movies on what can be done to see if it is what you are looking for prior to downloading.
      • #1816363
        I love Captivate – I use it for work. But you might also be interested in Camtasia, from Techsmith (I think there is a free trial download). SnagIt also has a recording mode – tho it doesn’t have a whole bunch of features.
    Reply To: Help! create a flash turorial
