• Heads up on possible fix for missing display settings
    Home » Forums » AskWoody support » Windows » Windows 10 » Windows 10 version 22H2 » Heads up on possible fix for missing display settings
    I set up a new laptop on (18/02/2023) Windows 10 Pro Build 19045.2728
    8 Quality updates installed at the time.
    Checked the laptop today before deployment.
    Unable to open display settings.
    Error: ms-settings:display
    This file does not have an appp associated with itfor performing this action.Please install anapp or, if one is already installed , create an association in theDefault Apps Settingspage.
    As it is a new system I took the risk and installed the deferred KB5023773 (Without the optional quality update) which fixed the issue.
    Maybe this will help someone …
    • #2548267
      I’m going to guess that it was slightly not happy and a new patch just made it behave.  There’s nothing in the older updates that would have triggered this.
      • #2548387
        Indeed, easy solution as it was a new install.
    Reply To: Heads up on possible fix for missing display settings
