• Gmail display problem
    For a couple of months the top of my Gmail opening page retains lines from previous actions (search, for example). I’m attaching a cropped screen shot.
    Originally, I had about 6 lines of a previous search. I manged to get rid of some of them, but these other lines have appeared – it’s all very capricious.
    How can I get this stuff off the screen?
    Thanks for any help….
    • #1241713
      Hi, Palomo, it all depends on how you have settings customised.
    • #1243738
      Try this:
      Log in to Gmail.
      Upper right hand of screen – Settings
      Click on Web Clips tab.
      Un-check “Show my web clips above the Inbox”
      Hope this helps!
    Reply To: Gmail display problem
