• Formula Problem
    I am hoping that you may be able to help me to select specific data . The problem which I haven’t yet been able to crack is to show a whole row of data with the following selection criteria:-
    a). Show the entire row if the ‘day’ is either a ‘Saturday’ or a ‘Sunday’ and
    . Show the entire row for any weekday if the ‘time’ is before “08:00” or after “17:00”
    Regards
    Braddy
    • #1183932
      The order in which you test is wrong. Try this formula in B12:
      =IF(OR($C2=”Saturday”,$C2=”Sunday”),B2,IF(OR($E2TIME(17,0,0)),B2,””))
      Then fill down and to the right.
      • #1183934
        Hi Hans
        Thank you for your prompt and excellent reply.
        Regards
        Braddy
      • #1183950
        Or, shorten to :
        =IF((LEFT($C2)=”S”)+(($E2TIME(17,,))),B2,””)
        Regards
        Bosco
        • #1183952
          Or, shorten to :
          Regards
          Bosco
          Hi
          Thank you for your input.
          Regards
          Braddy
    • #1184274
      Hi
      Hans and bosco_yip kindly supplied me with a formula which worked perfectly in the sample worksheet but when I applied it to the actual worksheet it does not work as required, for example in cheshire out of hours rows with n should not appear, any help would be much appreciated.
      Braddy
      • #1184276
        For others reading this: this should have been a reply in http://www.wopr.com/…howtopic=767898
        In the “Report 1” sheet, the value in cell E7 is a real time value, but the values in E8, E9 and E10 are text values, even though they look like times.
        Select E8, press F2, then press Enter without changing anything. This will convert the value to a time. Repeat for E9 and E10.
        • #1184277
          Hi Hans
          My apologies, I wasn’t too sure where to post this,I will take more care in the future.
          Thank you for the explanation.
          Regards
          Braddy
        • #1184621
          Hi Hans
          If you could indulge me just once more on this, I have 2000 rows to press F2 and enter is there a way I can automate this, I tried a macro with no success.
          Best Regards
          Braddy
          • #1184622
            Select the column with the times (on the Report 1 sheet).
            Press Alt+F11 to activate the Visual Basic Editor.
            Press Ctrl+G to activate the Immediate window.
            Type
            Selection.Value = Selection.Value
            Press Enter.
            • #1184623
              Type
              Press Enter.
              Hi Hans
              Does your genius have no bounds.
              Many Thanks
              Braddy
    Reply To: Formula Problem
