• Formula, function problem (Excel 2000)
    Hi all,
    I’m trying to count a certain color in multiple ranges, it works this function works fine from the worksheet, with one range, but when I try to add ranges to it, it doesnt’ work……anyone?
    CBC((InRange As Range, WhatColorIndex As Integer, Optional strsht As String, Optional OfText As Boolean = False) As Long
    Dim Rng As Range
    Application.Volatile True
    For Each Rng In InRange.Cells
    If OfText = True Then
    CBC = CBC – (Rng.Font.ColorIndex = WhatColorIndex)
    Else
    CBC = CBC – (Rng.Interior.ColorIndex = WhatColorIndex)
    Next Rng
    End Function
    • #904522
      Do you mean that you want to supply multiple discontiguous ranges? You can do that like this:
      =CBC((D3:F7,I10:K18),1)
      This will count the number of cells with black background in the range consisting of D3:F7 and I10:K18.
      • #905132
        Hans
        What does the 1 stand for?
        and, could I include more discontiguous ranges?
        Thanks, Darryl.
        • #905134
          1. The 1 is the WhatColorIndex argument to the CBC function. Excel has a 56 color palette, numbered 1 to 56. In the default palette, 1=Black, 2=White, 3=Red, 4=Green etc. So the 1 specifies black as color.
          2. You can use up to 31 (I think) discontiguous areas, for example replace the InRange argument (D3:F7,I10:K18) by (D3:F7,I10:K18,A22:C25,F38:W97)
        • #905135
      • #905133
        Hans
        Thanks, Darryl.
    • #904612
      Also, if the range name has multiple noncontiguous areas, you will need to use the Areas Method such as in post 405395.
    • #904613
    Reply To: Formula, function problem (Excel 2000)
