Hello all:
Two questions:
1. Can the default font size for comments be changed & how?
2. Can tiled spreadsheets be sync’ed so they can be scrolled together & how?
TIA for any and all assistance.
Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Fonts and scrolling (Excel 2000)
Hi Bill
1. The font size for comments is picked up from the font size for tool tips. To change the size do the following (instructions for Windows XP)
Hi Bill
(Edited by sdckapr on 02-Jul-04 07:56. Added PS with a better post)
Check out post 264633 for some code to change the comments after the fact to the desired size/ color, etc. Modify as needed.
I generally don’t recommend changing the tooltip default, since it affects most windows programs not just excel comments.
Steve
PS post 290956 is probably better since it avoids selecting. It also changes the fill color.
Steve
1. see the replies to post 290786.
2. Synchronized scrolling was introduced in Excel 2003 (some 15 years after Lotus 1-2-3.) You can synchronize two windows on the same worksheet in code: see Can’t Synchronize Windows By Choosing Arrange All
Notifications
