Hey!
So is anyone up for a seemingly difficult case involving a computer that overheats slightly and a fan that has gone hay-wire only to some degree according to temperature?
Sent it to the repairer but after 1.5 months he gave up. And no answers from the HP forum.
So here it is: HP 6360b, windows 7 professional.
Fan is always running on high, but it starts (and very aggressively so) already immediately after you turn the computer on (i.e: that’s not because of high temperature…). Fan has been changed: no difference, heat paste changed: no difference, CPU changed: no difference (clean out of course.. no difference). No difference if the computer is plugged in or on/off the internet. CPU is i5 and temp. is above 60c even though the computer is commanded to do nothing at all (using less than 5% cpu). So what is this? A motherboard problem? I heard that was almost impossible – or is that wrong? It’s not a thermometer problem while the heat sink does certainly heat up a quite a bit.
Anyone? Would be much appreciated!
Best, Emilie
