• Error Handling problem Excel 2013
    For some reason the error handing in a macro enabled workbook is not picking up when there is an error and dealing with it using an error handling code.
    The lines are>
    On Error GoTo err_Assignments
    Worksheets(“ASSIGNMENTS”).Activate
    Because the ASSIGNMENTS worksheet does not exist then I should be trapping this error and seeing a separate message to say the error has occurred
    The error handling is for now
    err_Assignments:
    MsgBox Err.Number & ” – ” & Err.Description
    It doesn’t catch the error and it throws the Run-time error ‘9’:
    Subscript out of range
    I tried on error resume next but still the runtime error is being displayed
    Have I missed a new setting in 2013?
    thanks
    alan
    • #1552247
      Darn it – simple settings check would have resolved this…apologies.
      Tools>Options>General> make sure error trapping is set as ‘Break on Unhandled Errors’
      • #1552255
        Hi
        In the VBA editor, it would be better to use..
        Tools>Options>General> make sure error trapping is set as ‘Break In Class Module’
        The reason is that if an error occurred in say, a Userform’s vba code, then the debugger will stop at the relevant line of code that caused the problem in the Userform’s code.
        zeddy
    Reply To: Error Handling problem Excel 2013
