• Edge and battery consumption
    Home » Forums » Newsletter and Homepage topics » Edge and battery consumption
    Good question from BC: Not sure if this is your area of expertise. If not, please ignore. That said…. If I may, wanted to see if you could comment o
    [See the full post at: Edge and battery consumption]
    • #40338
      Lipstick on a pig, as some say.
    • #40339
      Microsoft used a Surface Book for this benchmark.
      How about running a test like this on a PC that is more in line with what most users own. A PC with the minimum RAM requirement for Windows 10 … 1GB for 32-bit or 2 GB for 64-bit.
      The Surface Book starts at 8GB (goes to 128GB).
      Edge consumes RAM like a jumbo jet sucks in fuel and it is still not fully functional. MS promises it will do a lot more.
    • #40340
      It’s not the browser which is a hog (although Chrome gets more that way the more tabs you have open). In all browsers except Chrome, it’s Extensions which slow opening, closing and performance, es[pecially anything which phones home before firing up, like AdBlock, Ghostery or a host of other so-called Privacy Extensions. (Yes, they all collect and retain user data.)
      Bottom line is, with virtually no Extensions, of course Edge is fast. But at what cost in terms of functionality and usability?
    • #40341
      And to make this more on-topic, battery life and speed or performance in a browser are governed by the same principles. Exactly the same.
    Reply To: Edge and battery consumption
