I decided to go with a new post on this one about DHCP and my odd setup.
Equipment and Setup
- I have a T-Mobile Sagemcom Fast 5688W Gateway gateway (a dumbed down all-in-one modem/router combo). This gateway doesn’t have a true guest account feature and it’s just a name for sharing the main account. There is little you can do with the settings.
- To increase security, and have a guest account, I decided to purchase a TP-Link router (AX55).
- I hooked an ethernet cable from the Gateway’s LAN RJ45 port into the TP-Link router’s WAN RJ45 port.
- Back at the Gateway, I was able to turn off the WiFi and just use the TP-Link’s WiFi.
- Everything seemed to be working just fine for net connectivity.
Then I read somewhere that if both the Gateway and Router where “serving” DHCP IP, I might get conflicts.
- Since I can’t turn off the Gateway’s DHCP, I turned it off in the Router’s settings.
- After reboots for the Gateway, Router and all devices…….I found that most of the devices would not connect to the net.
I just barely know what’s going on, but something seems odd to me.
- If the DHCP server was turned off at the Modem, normally wouldn’t the DHCP IP’s from the Gateway just pass through the Modem?
- If I turn off the DHCP server at the Modem, are there some other settings I need to do?
- If everything is working with supposed “Double DHCP” maybe I don’t do anything?
- Is there a way to test to determine what is really going on?
I appreciate any ideas or help.
Mike
References
SagemCom Gateway: https://www.t-mobile.com/support/public-files/attachments/hint-gateway/Sagemcom%205G%20Gateway%20User%20Guide_English.pdf
Archer AX55 Router: https://www.tp-link.com/us/home-networking/wifi-router/archer-ax55/#specifications
