• Difficulties using Vlookup/Match/Index (2000)
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Difficulties using Vlookup/Match/Index (2000)
    Hi loungers,
    I’m having difficulties how to use Vlookup/Match/Index to resolve my problem.
    Here is what I’m trying to accomplish:
    Every month I want to check lost customers and new customers. I want to present the results in a certain way. The attached workbook resembles the scenario.
    Columns A and B represent the current situation while columns D and E the desired results. Column A is a listing of the current existing customer numbers in a sorted order. Column B is a listing from a different source of all customers, unsorted.
    I want to show the results in 2 columns matched by cell-to-cell as per the following:
    I would like column D to show in a sorted order the customers I have and if there is a new one, to offset while entering a cell with “New” and continue to the next match.
    Similarly, columns E should show “lost” where I’ve lost a customer, offsetting to the next match.
    I tried the aforementioned formulas and couldn’t get the results I wanted. Also, I thought a Macro combination will streamline the execution.
    I will appreciate any help!
    Thank you, -Tivoli0
    • #1096762
      Someone will probably come up with a clever solution, but I don’t know how to do this using formulas. I wrote the following macro to create the lists you want:
      Sub CreateLists()
      Dim r As Long
      ‘ Modify these constants as needed
      Const r1 = 8 ‘ First row
      Const c1 = “A” ‘ First column
      Const c2 = “B” ‘ Second column
      Const intColor = 6 ‘ Yellow
      Range(Cells(r1, c2), Cells(Rows.Count, c2).End(xlUp)).Sort _
      Key1:=Cells(r1, c2), Header:=xlNo
      r = r1
      Do While Not (Cells(r, c1) = “” And Cells(r, c2) = “”)
      If Cells(r, c1) Cells(r, c2) Then
      Cells(r, c1).Insert Shift:=xlShiftDown
      Cells(r, c1) = “New”
      Cells(r, c1).Interior.ColorIndex = intColor
      r = r + 1
      Loop
      See the attached version.
    • #1096767
      I am not sure it can be done with formulas. This is the method I used (which is different than Hans’).
      Steve
      Option Explicit
      Sub ExampleCode()
        Dim rCurrent As Range
        Dim rNew As Range
        Dim vNew() As Variant
        Dim iNewCt As Integer
        Dim rCell As Range
        Dim colUnique As New Collection
        Dim i As Integer
        Dim j As Integer
        Dim vTemp1 As Variant
        Dim vTemp2 As Variant
        With ActiveSheet
          Set rCurrent = .Range(.Range("A8"), _
            .Cells(.Cells.Rows.Count, 1).End(xlUp))
          Set rNew = .Range(.Range("B8"), _
            .Cells(.Cells.Rows.Count, 2).End(xlUp))
        End With
        iNewCt = rNew.Cells.Count
        ReDim vNew(1 To iNewCt)
        On Error Resume Next
        For Each rCell In rCurrent
          colUnique.Add rCell.Value, CStr(rCell.Value)
        Next
        i = 0
        For Each rCell In rNew
          i = i + 1
          vNew(i) = rCell
        Next
        On Error GoTo 0
        For i = 1 To colUnique.Count - 1
          For j = i + 1 To colUnique.Count
            If colUnique(i) > colUnique(j) Then
              vTemp1 = colUnique(i)
              vTemp2 = colUnique(j)
              colUnique.Add vTemp1, before:=j
              colUnique.Add vTemp2, before:=i
              colUnique.Remove i + 1
              colUnique.Remove j + 1
          Next
        Next
          If rCurrent.Cells(i)  colUnique(i) Then
            rCurrent.Cells(i).Insert
            rCurrent.Cells(i) = "New"
            rCurrent.Cells(i).Interior.Color = vbYellow
          j = 0
          j = Application.WorksheetFunction. _
            Match(colUnique(i), vNew, 0)
          On Error GoTo 0
          If j = 0 Then
            rNew.Cells(i) = "Lost"
            rNew.Cells(i).Interior.Color = vbYellow
          Else
            rNew.Cells(i) = colUnique(i)
            If i > iNewCt Then
              rNew.Cells(i).Interior.Color = _
                rNew.Cells(1).Interior.Color
        Next
        Range("A1") = "After"
        Range("B5") = "Sorted"
        Range("A5:B5").Copy Range("A6:B6")
        Range("A6:B6") = "Offset"
        MsgBox "Done"
        Set rCell = Nothing
        Set rCurrent = Nothing
        Set rNew = Nothing
    • #1096777
      Here is a way with formulas, though it is not pretty and it requires 4 intermediate columns. I don’t hold much hope that the 4 intermidiate columns could be made into arrays…
      Perhaps there is a different scheme….
      [Personally, I think Hans’ code is probably the best bet…]
      Steve
      • #1096780
        I didn’t think it was possible using formulas, so thanks, even if using a macro is probably easier here.
        • #1096791
          I tried some things, gave up and went the macro route, then after thinking some more, came up with the convoluted method. I couldn’t come up with any Array schemes to make the intermediate columns not be required (though even if I could make them an array, I am not sure the mega-formula could handle it)
          The macro route is easier and I like the simplicity of yours is better than the route I chose. I decided to still post mine (after seeing yours) since some of the techniques used may be useful to someone for other tasks
          Steve
          • #1096795
            Your macro is a bit more complicated than mine, but it demonstrates some very useful techniques, so it’s definitely worthwile to see it.
    • #1096923
      Attached is a solution using only 2 columns, as required.
      Each column requires a fairly complex array formula which essentially tests for the next customer in the sequence from either column and then displays either the number (if it is is in both source columns) or ‘New’ or ‘Lost’ if it is in only 1.
      The formula also contains an extra if statement to test if the maximum customer number has already been reached. This would allow for an output table to built that does not need to be the exact size. Further power could be added to this solution by using dynamic names for the data in columns A and B, this would ensure that once created the formulae would always include ALL customer numbers in the calculation.
      I hope this helps
      • #1096927
        Thank you.
      • #1096945
        thumbupImpressive. Much simpler than my formulas and no intermeidates. Thanks
        Steve
        • #1099170
          I am back…
          Thanks for the replies!!!
          I’ve been experimenting and trying all the ways to achieve what I was looking for.
          It’s amazing what varieties exist.
          In applying the different techniques and principles to further the experimentation,
          all worked great – as long as I manipulated numbers. However, I had problems working with strings.
          The attached worksheet demonstrate what I mean.
          I am really thankful for your input and was able to learn from you and apply the acquired knowledge.
          I hope you will be able to assist me and suggest a resolution to the attached problem.
          Thank you!
          Tivoli0
          • #1099179
            This version of the macro I posted earlier should work with text values:
            Sub CreateLists()
            Dim r As Long
            ' Modify these constants as needed
            Const r1 = 4 ' First row
            Const c1 = "A" ' First column
            Const c2 = "B" ' Second column
            Range(Cells(r1, c1), Cells(Rows.Count, c1).End(xlUp)).Sort _
            Key1:=Cells(r1, c1), Header:=xlNo
            r = r1
            Do While Not (Cells(r, c1) = "" And Cells(r, c2) = "")
            If Cells(r, c1) Cells(r, c2) And Not Cells(r, c2) = "" Then
            r = r + 1
            Loop
            • #1100400
              Hello Hans,
              Thanks for your reply!
              I tested it and it worked like a charm. I tried to modify it for a yet another task and had difficulties. I just coudn’t figre out which way to go. I guess I have to strugle with the code.
              I attached a sample worksheet. If you can guide me it will be wonderful as this is the last step I need to overcome to finish a project.
              THANK YOU!
              -tivoli0
            • #1100406
              This is a completely different task – it doesn’t have to do anything with sorting data. You can use simple VLOOKUP formulas: in F8,
              =VLOOKUP($E8,$A$8:$C$12,2,FALSE)
              and in G8
              =VLOOKUP($E8,$A$8:$C$12,3,FALSE)
              then fill down.
            • #1100441
              hello Hans,
              Yes, I know it’s a completely different task which I had tried to accomplish on my own.
              It seems I got blacked out from the previous posts. . .
              Anyway, your reply was on target and thanks to you, and the others who replied, I was able to accomplished what I set forth.
              Thanks a million!
              -Tivoli0
          • #1099388
            My current formula approach cannot help because it is limited to sorting numeric values. It may be possible to adapt but that would be far more complex than any VBA solution would ever be.
          • #1099438
            To jump back to the original problem (no text), I think you can do it with non-array formulas making use of SMALL and COUNT and some expanding ranges. Not as elegant as the array or as clear and logical as Steve’s formulas, but I figured I’d add it anyway.
            Best,
            • #1099441
              I get a message about circular references when I open your workbook, and if I press F2 then Enter in any of the formula cells, the result changes to 0…
            • #1099444
              Interesting. It is a little circular – cells refer to themselves as parts of ranges in counts, etc.; perhaps I should have mentioned that — I work at a place where everyone works with iteration on so I forget about the other possibility sometimes. The attachment does work for me as soon as iteration is turned on, though.
              Best,
            • #1099447
              The problem is that the calculation and iteration settings in Excel are determined by the first workbook that you open, they remain the same during that session unless you change them explicitly.
              So if I open your workbook while Excel is not active, your settings will be applied and the formulas work correctly.
              But if a workbook is already open with the default settings (automatic calculation, no iteration), opening your workbook throws up the circular reference message.
    Reply To: Difficulties using Vlookup/Match/Index (2000)
