Hi,
Apologies in advance for the lengthy post. Anyone patient enough to read through all this has my sincere thanks!
In short, I have a problem with my custom built PC that I think may be caused by a defective power supply unit (PSU) and I’d like your input as to whether you believe my hunch that the PSU is the culprit seems correct and if so whether I should replace the PSU sooner rather than later.
Here’s where this starts to get lengthy: the affected computer was assembled a few years ago and I have it connected to a wall socket (along with monitor, speakers and printer) through a power strip. The power strip has its own on/off switch and when I’m done using the computer for the day I switch it off (of course after having shut down the computer).
The problem I’m seeing – which happened since the very day I finished assembling the computer – is the following: I turn on the switch on the power strip and then push the power-on button on the computer, but the system does not boot up, it sits there with a blank screen, fans spinning and discs working without ever reaching the POST screen nor does Windows load. When this happens the power-on led remains dark and a led on the motherboard lights up indicating a “CPU fail”.
When this happens, I press the power-on button for a few seconds until the system powers down and then press that button again: the power-on led is lit, the screen lights up with the POST screen, Windows loads properly, no warning leds on the motherboard are lit and the whole system works correctly, i.e. it is perfectly stable and I can put it through as much stress as I like without trouble. The few BSoDs or freezes I’ve had were always traceable to a software problem and I never noticed any tell-tale signal of hardware failure.
After several tests across the years (see list at the bottom), I suspect the culprit of this odd behavior may be the PSU: maybe it’s defective and its over-current protection kicks in unnecessarily when the system is “cold” and I’m powering it up the first time after I switch on the power strip. I’m assuming the “CPU fail” led on the motherboard simply lights up because the over-current protection prevents current from reaching the CPU to protect it.
Do you think the above problem may be caused by a defective PSU? If so, would you recommend that I replace the PSU right way?
I didn’t use a “cheapo no brand” PSU for this computer, it’s a 650W Antec TruePower Classic PSU (TP-650C) which is more than enough for this system (at most my system pulls about 420W), but we all know that even branded products sometimes can be defective.
BTW, the problem seems to be increasingly frequent since a few days ago. That’s when I did something different after the system failed to start correctly. In fact, after shutting off the system I didn’t press the power-on button right away, instead I switched off the power strip to disconnect an unneeded battery charger that was plugged in, switched on the power strip and when I pressed the computer’s power-on button nothing happened at all: the computer seemed to be dead with no fans or disks working, no led lit on the motherboard. I assumed either the power supply or the motherboard had died, but then after a few minutes I could power up the computer again and everything was working just fine all over again.
Here’s a list of things I tried to trace the source of the problem:
– replaced the CPU with a different one;
– replaced the video card with a different one;
– replaced the memory modules;
– ran the system without a video card plugged-in and using the on-board GPU;
– ran the system with a single memory module;
– put memory modules in different memory slot(s);
– used a different power strip;
– used a different wall socket at home as well as a wall socket in an entirely different building;
– updated the motherboard’s BIOS at least twice to use the latest version;
– disabled CPU C-states in BIOS;
– disabled use of XMP profile for the memory modules;
– checked for failed or close-to-failure capacitors on the motherboard and found none;
– checked for damage on PSU cables and found none;
– checked that all cables are properly plugged-in onto the motherboard;
– connected the reset switch to the power-on pins on the motherboard to test whether the power-on switch is defective.
The only things I didn’t try so far are replacing the PSU and replacing the motherboard, but because the problem generally happens only on starting up “cold” and the system is otherwise stable, I’m thinking it’s more likely that the issue is with the PSU rather than the motherboard.
Any helpful input is appreciated, thanks!
